ANYONE WITH Rotora Big Brake Kits SETUP ON 18S or >
Old 02-08-2005 | 06:19 PM
poisx7's Avatar
Question ANYONE WITH Rotora Big Brake Kits SETUP ON 18S or >
pLS GIVE ME SOME INSIGHT INFO:
IS IT POSSIBLE TO DO A DROP ON A Rotora Big Brake SETUP ON 18S and with what rim and tire specs.
If so could i acheieve the following 4 objectives and what tire or rims specs is recommended, people keep saying the stock rims come with a 55 + offset and i know the Rotora BB sets the offset off and i was also told i might need to use 5 mm spacers and that our rims come with a 64.0mm centerbore. i hear this things but do not understand it. So in lameman terms what tire and rim specs should i be shopping for again to make the Rotora Big Brake Kits work without rubbing the fender. pls give the specs i.e (18 x 7.5 x 235) with a rim offset of 42+
U COULD REFER TO :
https://acurazine.com/forums/showthread.php?t=108911
(1)i want to keep the brake upgrade project. say with rotora BB &
(2)i also want to drive on 18s preferably 18 X 7 or say 18 x 7.5, (235,245) &
(3) IF I CAN I WANT TO AVOID USING THE 5MM SPACERS .
(4) I ORIGINALLY WANTED TO DROP THE THING A FEW 3/4 INCHES WITH HR SPRINGS, MAY BE I WOULD HAVE TO LET THIS ONE GO.
what tire or rims size would anyone recommend pls give wheel specs:
yesSIR-S
05-13-2016 05:42 PM
HOWELLiNC
10-19-2015 03:26 PM
HOWELLiNC
3G TL Photograph Gallery
24
10-08-2015 03:15 PM
HOWELLiNC
09-10-2015 01:39 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: ANYONE WITH Rotora Big Brake Kits SETUP ON 18S or >
