Another Will This Fit Thread
Originally Posted by fsttyms1
114.3 is the correct bolt pattern. +42 is really starting to cut it close. you are going to have to run a narrow tire
The offset, is it the thickness of the wheel? And also are tires for this type of rim going to cost more?
Thanks for the replies.
All you ever wanted to know about offset...CLICK HERE
18x8 +48 offset = 18x7.5 +36 offset.
0.5 inch = 12.5mm approx
The main thing is what tires you are going to run. If you run 225-45-17, I am pretty sure you will be OK but if you run 235-45-17, you may have to cut the rear fender tab.
I had 18x.7.5 (+42)Racing Hart M5 (Mono Block) on my previous car which was TL-S. I ran it with 235-40-18 and it rubbed so I roller my rear fender. Later I found out that all I had to do was just cut the rear fender tabs.
By the way, My car was not lowered.
acura_dipset_tl
Jan 1, 2016 03:02 PM
Sep 17, 2015 09:01 PM
