All 5 lugnuts loose!
On my way home this morning I noticed a sort of metallic clicking / rubbing noise while I was driving. The noise seemed to disappear when I would accelerate, but would reappear when I would slow down. As I continued to drive, I noticed that it seemed to be getting worse. It almost felt as though the tire was flat because there was a rotational thumping noise that had become apparent. I decided to pull over and inspect the left front tire which is where the noise was emanating from. Upon further inspection there were no nails or sharp objects imbedded into the tire. So I continued on at a very slow pace until I got home. I decided that I would remove the tire to see if I could determine where the noise was coming from. To my surprise I found out that all the lugs on the left front wheel were loose?!?!? I proceeded to tighten the lugs and inspect the other wheels, none of which had the same problem. I guess my question is, is there any chance that I damaged anything (pins/ bolts on the rotors, any part of the suspension) on the drive home? The drive was approximately 10 miles. I tried to drive as slowly as I could given the movement of the traffic. After tightening up the lugs, I took the car out for a spin and everything seemed fine. Just looking for a little input, thanks guys!
Originally Posted by NSXNEXT
Maybe someone was trying to steal your wheels? Do you have wheel locks?
I doubt there any damage, take the wheel off and check the threads on the bolts. Also check the lug holes in the wheel to see if it was gouged up at all.
Again, I doubt there was any significant damage.
Originally Posted by fsttyms1
I agree. I doubt there is any damage. With aluminum wheels its always recomended to retorque the wheels after 30 miles or so of driving after teh wheel has been off.
Originally Posted by TacoBellSauce
didnt this happen to at least 2 other members, one, if i remember correctly, who lost a wheel on the highway?
it happened to me before on one of my 19s on my TL.. i lived in apt. complex an d i had a feeling these dirty mexicans had an eye on my car and tried jacking the wheels.
all nuts were loose except wheel lock.. after i got off the freeway, i only had 3 nuts on. scary.
Guys, this happened to me too last November, but I was also unlucky to the fact that I too was driving on the highway and decided to get off when the Wheel flew off nearly took someone out, and there was about 2,300.00 dollars of damage to my car. I say you better check those lug studs because all 5 of mine sheared at the rotor .
In my case, I noticed a rattling / clicking noise as I was returning home. Soon there after, I started to feel unevenness to the rotation of the tire. It almost felt as though I had a flat tire. I decided to pull over, but after a brief visual inspection of the tire, I could find nothing imbedded in the tire. So I decided to finish off the rest of my short drive home. Upon jacking the car, I realized that all the lugs were loose. How unnerving.
Yea man, the car vibrated real bad before the wheel flew off, i too thought i had a flat. But even earlier to that, I heard the same clicking noise and i kept checking to see if anything was wrong, but found nothing. I guess it was probably real bad luck or something.
ITSJESTER
17
12-06-2018 02:29 AM
dainmezron
10-16-2015 06:56 PM
