Alignment after strut replacement?
I think the answer to this is no, but just wanted to confirm. I just had my alignment done recently and now want to replace struts w/ aftermarket (keeping stock springs). I don't need to redo the alignment if I'm not changing out the springs, correct (assuming car doesn't pull, etc)?
Also, is it OK to take this to a tire place to do (Big-O, Evans, etc) or should I just stick w/ my independent Acura guy, even though he charges more for the labor?
Since you're removing the suspension components to install the new shocks, you should wait a few weeks then get an alignment. Do you have to? No, but if you're alignment is outta wack, you may cause premature tire wear.
marcelft
Jul 10, 2018 06:17 PM
acurajj
Feb 14, 2016 02:28 PM
Zonian22
Nov 14, 2015 01:20 PM
