99 tl
i never made a diy when I did mines, but I'll give u steps on how I remember it. its pretty simple. Having the car in the air makes it a lot easier.
1. take ur wheels off
2. remove the big bolt on the rotor: (it is circled in red)
3. I got a crow bar type of tool and put it when the inside of the axle meets the main part. and tried to pull it out.
-It in on the inside, where the axles are connected too. (also circled in red, the blue circles are the part of the axle that connect to the rotor)
4. and you basically done taking the axles off, and repeat it backwards to install the new ones.
5. put the inside of the axle back in
6. Check if the axle is all the way in!!
7. put it in the rotor and tighten the big bolt back to the rotor
this is how I remember doing it, It been a while lets other chime in if I missed a step.
If i missed a bolt, it nots hard just look up where the axle is connected to and see if there is a bolt that connected. (common sense)
