5x100 - 5x114.3 conversion?
Old Dec 5, 2005 | 09:29 AM
big mike 13's Avatar
is this possible to change a 5 x 100 into a 114.3?
if so, is there a bad side to it..
thanks
Old Dec 5, 2005 | 10:09 AM
Pure Adrenaline's Avatar
Dragging knees in
No, you can't change the bolt pattern on a wheel. You could run an adapter, but that's usually not a good idea.
Old Dec 5, 2005 | 11:15 AM
TLgunner's Avatar
Originally Posted by Pure Adrenaline
... You could run an adapter, but that's usually not a good idea.
adapters will cut into your offset and finding wheels with enough offset to begin with is a b*tch.
Old Dec 5, 2005 | 04:05 PM
fsttyms1's Avatar
Old Dec 5, 2005 | 04:26 PM
finding used wheels for our car is a bitch!
but then the WRX has like the perfect width and offset, but theyre freaking x 100!!
Old Dec 5, 2005 | 04:31 PM
fsttyms1's Avatar
yea our cars are harder to shop for than most. We have a Very high offset need.
Old Dec 7, 2005 | 07:39 PM
Phrosttz0's Avatar
yep the only thing i hate about our cars is the goddamn offset issues
Old Dec 7, 2005 | 08:11 PM
NSXNEXT's Avatar
Not completely true. A wheel repair shop can fill the holes and then redrill them to be 5x114.3.
Would I do it? HEEEEEELLLLL NO!!! You could be dealing with structural integrity issues if they do it wrong.
Old Dec 8, 2005 | 10:06 AM
ABP-TLS's Avatar
Wifes Car
I dont know if this would work on this car ive never taken the wheel off cause I dont have the key for the locks
I also own a Thunderbird and we have the same problem most people switch to a Mustang hub in the front with the bigger brakes and have the rear hubs redrilled to fit the Mustang bolt pattern, the front we can find in the junkyard but the rears would have to come off a Cobra and they are a little harder to come across, and ive never heard of anyone having a problem
Its an idea maybe just have the hubs and brakes redrilled????
Old Dec 8, 2005 | 11:09 AM
fsttyms1's Avatar
By time you did that and spent the money, finding someone who wont mess it up Trying to do that you could have easily bought a pair of rims to fit the car correctly
Old Dec 9, 2005 | 09:19 AM
ABP-TLS's Avatar
Wifes Car
True but there are alot of people that want a certain wheel and cant get it in their bolt pattern
You could do it your self if you know some one who uses CAD just have them draw up a pattern and take you time drilling thats how we do it
Brad
Old Dec 9, 2005 | 11:21 AM
fsttyms1's Avatar
Brad
Bolt pattern isnt really the issue with our cars, its offset and thats not something we can make different. Finding something with the correct offset is far harder than the correct bolt pattern
Old Dec 9, 2005 | 12:25 PM
most of the WRX wheels ive seen have been 18x7.5, 43 or Higher offset, but the damn 5x100 bolt pattern
Old Dec 9, 2005 | 02:05 PM
fsttyms1's Avatar
But 43 is really too low for our cars
Old Dec 12, 2005 | 10:59 AM
ABP-TLS's Avatar
Wifes Car
oh i see i thought it was the other way
Old Dec 12, 2005 | 11:33 AM
Dragging knees in
5x114.3 is one of the most common bolt patterns in the industry.
Old Dec 12, 2005 | 02:36 PM
fsttyms1's Avatar
Old Dec 12, 2005 | 07:28 PM
NSXNEXT's Avatar
STI is 5x114.3 but the center bore is too small to fit.
Old Dec 6, 2007 | 10:12 PM
NemesisMachine's Avatar
If you bring the wheel to a machinist, they can punch the center out to the right size. my friend did that with a set of miata wheels for his SI. They machined the wheels out using the spare for the size. my .02
Old Dec 6, 2007 | 10:38 PM
Razzi's Avatar
T-Swzy
if the offset is too low, could you toss in a spacer for a few mm and have it fit? someone told me it'll work just fine
Old Dec 7, 2007 | 08:29 AM
fsttyms1's Avatar
A spacer would throw it the wrong way and go even lower.
Old Dec 7, 2007 | 11:47 AM
02type-s's Avatar
-Arsenic-
Not true. Depends on tire size, wheel size, and width. Why do so many people on here only do what "bolts right up"? Thats not customizing, thats throwing parts on. C'mon Kris, you did that bad-ass swap in your TL, making it a TL-S 6, and you make it seem like rolling fenders is out of the question. If you roll fenders and cut tabs, you can fit offsets below +40! I mean no disrespect, but considering the one-off work you have put into your car, I would think you would be the last person to say half the things you do about offsets.
Old Dec 7, 2007 | 12:26 PM
fsttyms1's Avatar
Well we mostly state what we do because MOST dont want to have to roll fenders and possibly damage their paint. They want what bolts on. Im starting to think there is a big difference in front fenders between the 99-01 and the 02-03. I can tell you with out a doubt that there is NO way i could get a +40 (18x7.5) on my car and no amount of fender rolling would change it. My +50 is flush with the front fenders. (and nothing is different due to my swap) I put a +38 18x8 and it stuck out a solid 3/4-1 inch in the front
Old Dec 7, 2007 | 12:33 PM
02type-s's Avatar
-Arsenic-
That is very strange. I thought they were the same. I know I didn't get a freak fitment or anything, because I talked djescobar into getting some TSWs with my same specs and with rolled fenders and cut tabs he is rub-free as well. Hmmm. Now I'm curious to see if there in fact IS a difference in the flare of the fenders from 99-01 and 02-03. How would we find this out?
Old Dec 7, 2007 | 01:56 PM
WillrunifChased's Avatar
The ICEMAN
I don't know if there is a difference or not but I rolled on a set of 18x8 +40 in the front and only rubbed occasionally over big bumps going fast. I really think it depends on the manufacturer and the tire size.
Old Dec 7, 2007 | 02:10 PM
02type-s's Avatar
-Arsenic-
Im prettly low with no negative camber, and my 19x8 +40 have never rubbed in the front. Wheel offsets do vary slightly from manufacturer to another, but VERY slightly. I just don't understand how fsttyms1 runs a +50 and its flush. That doesnt make sense to me. A +50 should be recessed in a little.
Old Dec 7, 2007 | 03:18 PM
fsttyms1's Avatar
See i dont know how thats possible?? THe +38s i threw on were sticking out so far they would have rubbed no matter what.
Old Dec 7, 2007 | 03:29 PM
fsttyms1's Avatar
It isnt exactly flush but its less than 1/4 (225/40 tire is flush) inch which is what roughly 4mm?
All i know is from what ive tried and seen
Old Dec 8, 2007 | 01:04 AM
Phrosttz0's Avatar
19x8.5 45offset, no rubbing, doesnt sit flush enough for me in the rear..
BreezyTL
Jul 26, 2016 12:52 PM
HondoGermany
23
Jan 8, 2016 03:01 PM
emseecoy
Sep 29, 2015 12:39 AM
racersky
Sep 24, 2015 02:42 PM
acuradriver925
Sep 12, 2015 08:25 AM
