20x19 offset 50 is it going to fit??
Hey guys I just bought my first tl and am not sure what wheel set ups are possible for it.
I was just wondering if these would fit b.c I found a killer set of work eurolines for dirt cheep.
I plan on running ground controls droped all the way for right now and some sorta rear camber kit to get that "stance" any help would be nice.
I don't think they will fit at all (20x19) ...maybe with a slight pull
These are 20x15 on my brothers truck with 40" tires... these things are WIDE and you want to go 4" wider
I'm a thrill seeker in my
Well if they actually are 20x9 50+ then they would stick 2.7 inches farther out than the TL-S' stock 6.5" wide wheels. I think because they're 20" wheels you'd need to roll your fenders regardless of the higher offset. And I would expect the need for atleast -1.5 degrees of camber in the rear.
I have 18x7.5 +42 with a 225/40 tire and I just escape rubbing in the rear. I'm dropped on Teins at the reference height with -1.6 degrees of camber.
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
xsilverhawkx
09-28-2015 06:51 PM
