2002 TL Type S owner, lower control arm question
I made this account to ask a few questions, but the most important would be about the piece of metal rod that connects the lower control arm to the front crash bar, what is it called so I can get one?
Welcome to the forums.
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions forum to the model specific forum. |
Originally Posted by Carlos Rios
(Post 16404563)
https://www.acuraoemparts.com/auto-p...lower-arm-scat How many miles on the car? |
@Carlos Rios Did you ever end up getting new radius rods? how do you know they were bad?
I
Originally Posted by whitetiger5
(Post 16461430)
And the rod is pushing the whole assembly to the rear. It could be the crash bad or the part the lower control arm connects to but the rod is the easiest to replace. |
what kind of accident? any pics?
(Post 16461446)
alright...good info. Since you mentioned hit a curb: do you know if the wheel is bent?
There is a very easy way to check for bent wheels: these will show up as vibration in the cabin at highway speeds. |
Carlos Rios, have you replaced the strut rod yet? If so did it correct the issue. I have the same problem still although I haven't installed the new rod or bushings the car was aligned and is tracking properly. Visually and measured, the tire is 3/4' further back than the Drivers front tire. My repair shop rechecked the frame and said its perfect. I don't understand why its still 3/4" further back.
Any insights??? |
Originally Posted by WhiteAcura2003
(Post 16507336)
Any insights??? |
