19's rubbin
www.grounded4life.org
19's rubbin
i just put on my 19x8 diablo vienna rims with 235/35/19 toyo poroxe 4s and when im goin fast and hit a bump or have 1 or 2 people in the back they rub can anyone who has had this problem tell me what i should do I heard about gettin the fenders rolled will thay work and if so how do i go about doin it THANX
first what offset are you running?
2nd it may only be the rear tabs of the rear bumper?
that would be the problem, not much you can do. you need atleast a +47 for a 19x8 with a 235 preferably a +50 to +55
yeah those diablo rims run low offsets i had the lionharts and i had to take them off cause they were rubbing real bad , you can't even roll your fenders to fix the problem.
It will help if you trim some of the plastic "tab" near the top rear of the wheels well...
I did mine with a dremel and I still have about 2-3mm of clearance with 19x8 +49mm with the suspension bottomoned out.
Wow, that's a low offset. If your wheels aren't sticking out past the fender you can always fix your rubbing issue by rolling the fenders. I have a feeling trimming the Tabs won't work in this case. If they are sticking past the fender, throw them up on ebay.
Originally Posted by AcuraTLS03
no way your gonna fix that rubbing without spending a nice chunk of change. do yourself a favor and sell the wheels or return them if possible.
![rtfm](https://acurazine.com/forums/images/smilies/rtfm.gif)
18"AndUpNoSitinOnMinors
[B]i had the same problem same rim/tire size. went to a 225/35/19 now i can fit a full car load with some rubbing over bumps and no fender mods
i have 20*7.5 TIS 03 nitto's 225/35/r20 on my 02 tl.s i just drop the front not the rear with H&R 1.7 inch no rub. i did had to trim the rear the bumper and roll up the rear fender a little. also i have had five people in my car and once in while when i would do turns it will do little rubs
617acura
03-11-2011 03:05 PM
