18x9, +30
18x9, +30
i have not seen many people attempting to run aggressive wheel sizes on 2G tl's.
has anyone run a wheel with similar spec's?
im sure i would have to do some quarter rolling, and probably mess with the camber.
Leave it up to the man who has a Naaasty CL. Makes me want to steal your wheels.
jjashaa that pic is now my frickin Wallpaper.
grip, how low are you planning to go? Do you have plans for certain suspension?
eh from experience you should just run maybe like -1 or 1.5 camber and go as low as you can as long as your toe is fine your tires should be okay it will still wear but not as much if the toe is correct i was running -3 before. and if you dont really want to run camber just roll your fenders and run like 215 series tires with 8.5 rims the stretch will look great
something like 19x8.5 +30 or +35 would be flush in front, rear should be around the same if u run almost no camber.
someone with more knowledge than me needs to redo derrrick's thread on "will it fit"
we can be a lot more agressive then he originally thought.
i'm trying to see if i can fit stock g35 wheels on my car...
Front wheels
Wheel Size: 19x8.0
Wheel Offset: +30
Wheel Brand: rays
Tire Size: 225/40/19
Rear wheels
Wheel Size: 19x8.5
Wheel Offset: +33
Wheel Brand: rays
Tire Size: 245/40/19
i know i'll have to roll fenders and cut tabs but would i also have to run camber and/or get 225 tires for the rear?
Front wheels
Wheel Size: 19x8.0
Wheel Offset: +30
Wheel Brand: rays
Rear wheels
Wheel Size: 19x8.5
Wheel Offset: +33
Wheel Brand: rays
all this talk is making me wana try that my idea with 18x9 +20 setup...which definitely wont work lol
18x10s in the rear, 18x9.5s in the front.
the wheels will always work, its everything else that needs changing lol. i can ride with it all the way down but i can ride with it with the tire still tucking in the rear.
and add about +17 more to that 30
Im a huge newb with wheels and all this camber talk, I did a big time rookie mistake and bought some 19x9.5 in the rear. I didnt do my homework and after reading all this im realizing i messed up. What would I have to do if i wanted to make them work with out doing major work? Or is that even possible? I dnt want to drop it much so I would like to see what im in for. CONFUSED!!!!
i had 18x9 +35 w/ 225-40-18 and rolled fenders before..
now 18x9.5 +31 w/ 225-40-18
will fit, cut bumper tabs and roll fenders. p.s. im on air ride tho... it tucks in sickly when all the way down..
19x9.5 +45 all around also? or rears only? either way thas not gonna be an easy fit by any means, that size (even wider) has been done before tho...
Front wheels
Wheel Size: 19x8.0
Wheel Offset: +30
Wheel Brand: rays
Rear wheels
Wheel Size: 19x8.5
Wheel Offset: +33
Wheel Brand: rays
Front wheels
Wheel Size: 19x8.0
Wheel Offset: +30
Wheel Brand: rays
Rear wheels
Wheel Size: 19x8.5
Wheel Offset: +33
Wheel Brand: rays
can you guys start posting pictures, along with your spec's?
i purchased a set of Rays G35 wheels with tires to use as a refrence....they are now for sale.
8.5wide, +33 pokes out about 1/2"-3/4" in the rear
8 wide, +30 poke's about about 1/4" in the rear
i want to order a set of 18x9, +30 wheels, but i need to see some cars actually putting these width's and offset's to use to gain a little confidence in my future setup. (i cant afford to purchase another set of wheels just to see how they fit.
anyone want to buy some G35 wheels? i have them on ebay (user id= gripfab, item # 220321592392)
