18x9 / 18x10 wide setup
i just got my new wheels work varianza t1s 18x8fr and 18x9rr but now i feel like going even more wider
i want to try to put on the rear wheel (18x9 +42 offset) to the front and order some new 18x10 for the rear.
do you guys think this will work. and what kind of offset should i run for the 18x10 wheel to fit it in the rear. and what will i need to do to make this work
Always a Honda =Þ
is it 18x10 +42 also? .. it will work...with alot of the following
strech tires... i have 265..slight strectch...255 medium go 245 for hella stretch and less rub
roll fender.. how ever you know..
cut bumper tab...ride once around the corner..you see your bumper melting away.. cut around that..
cut off the inside of the coner where the bumper meet the quarter panel... trust me..a car packed it gets annoying..
Told Ya'LL...DYNASTY !!
you'll get some natural camber just from slamming it.. i chose not to go with a front camber kit at the moment and the front has about -1.5 of natural camber jus from slamming it.. so that coupled with the camber kit should be more then enough adjustment to get the specs you want up front..
im running 18x9 and 18x10 ... im thinking about selling them so hit me up if ur interested
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/do-work-son-work-wheel-content-inside-818204/
