16in Wheels on a TL-S
I'm looking to put 16in wheels on my TL-S for winter.
(don't have it yet, getting it in 2-3 weeks so can't check in person yet)
From what i've looked into the TL-S doesn't have larger brakes than the regular TL, so 16in wheels should fit fine on a TL-S.
The reason is needing to buy steel wheels and tires, and I can save $200-$300 by going an inch smaller.
Does the TL-S have the factory alloys or aftermarket custom wheels on it ?
If they are still the OEM's , then why don't you consider using them for the winter tires and treat the old girl to some new shoes in the spring ! There are alot better looking rims then the stockers, in my opinion. So save your money up and dress her up a bit next year.
SpicyMayo (11-01-2012)
Thanks for the confirmation.
It currently has the stock wheel/tires on it. I don't plan to modify this car much, The plan is for this car to be my stock daily driver, and keep my other project cars/bikes going.
Yes 16s will fit.If you get them thru someone like the tirerack they will make sure its the correct wheel to fit over the caliper.
JByron
01-08-2016 09:49 PM
