yes or no????
Old Aug 30, 2010 | 05:03 PM
i_g0tz_s0l3's Avatar
I Heart My
yes or no????
2003 tl-s.......sooo i went to get my oil change today and decided to get my tranny fluid changed too and the guy at tech lube said ur fluid needs to be changed but the thing is ur car is at 168k u might mess up ur tranny if u do change it cause the tranny might not be able to handle the need fluid he said its a 50/50 chance but if i keep riding wit this fluid it will only get dirtier note i bought this tl-s on its second tranny wat should i do please help!!!! oh yeah ever since i had theres been no tranny problems
Old Aug 30, 2010 | 05:11 PM
fsttyms1's Avatar
do a single drain fill. NEVER have a oil change place do it. They like to use flush machines which honda DOES NOT want you to use. Also use Honda fluid!
Old Aug 30, 2010 | 05:56 PM
ANC297's Avatar
Bonki' Ehrite!
I just did mine 2 nights ago, and it was basically an oil change...Just drain and refill..
Do it yourself. The fluid cost me 28 bucks through Acura.
Old Aug 30, 2010 | 05:57 PM
01tl4tl's Avatar
since you have a 2nd trans its not as bad on miles as the shop guy thinks
BUT
I agree with fsttyms1- do a simple 3qt drain and refill on the trans fluid
thats a little under half its capacity and will be ok
use only HONDA atf from honda dealer or import parts store
anything else spells death
make sure to loosen and retighten the fill and drain plugs when cold... or its a pain when warm
Do 15 minute freeway cruise to warm the fluid and get crud in suspension.. so it will drain out
DO NOT add any trans cleaner!!
Old Aug 30, 2010 | 05:58 PM
01tl4tl's Avatar
it will drain out 3 to 3.2 have even heard 3.5 qts
so buy 4
Old Aug 30, 2010 | 05:59 PM
AMUA6's Avatar
ScoobyZINE
^^^ What they said
Old Aug 30, 2010 | 07:17 PM
ANC297's Avatar
Bonki' Ehrite!
BUT
Hmm, I cruised around for about 30 mins right before I started, and both plugs were a breeze to remove..I did hit the drain plug with pb blaster due to rust in the ratchet square though, and I used an extendable ratchet.
Old Aug 30, 2010 | 11:20 PM
01tl4tl's Avatar
probably because it was a recent trans
you were lucky
PB rocks!
I write in generic terms for future readers: stop, ck the bolts when cold--before they climb under a hot car
Plus I was taught make sure the filler plug opens before you pop the drain plug-
would be a real problem getting fluid back in!!
Old Aug 31, 2010 | 06:56 AM
ANC297's Avatar
Bonki' Ehrite!
Yup...And yeah, I learned always to open the filler first as well.
