why does my car shakes?
more info is needed. Any check engine light? Mileage? Last service (tuneup/plugs) What is the low rpm? 750rpm or is it lower?
car has 181xx, types2002. it shakes for 2/3 sec on lower rpm,like in between 1/2 gears, like when i am going between 20/30 kms. it happens once in a while, i am not sure what is cusing this problem? i changed transmission fluid, cleaned egr valve. no engine lights, all the serive such as transmission fluid,oilchange has been done in time
B A N N E D
B A N N E D
filter??? the transmission filter, it sits on top of the tranny, right below the intake tube (it's the black cylinder), switchs=the pressure switchs on the tranny (they get dirty fron dirty ATF), and also clean out the solenoids filters and such
and as will proably see, is that our tranny's are not the best out there (there are dedicated sections to the tranny issues on here) (in order for them to last, they are kinda maintence whores/high maintence)
Inspect your motor mounts, but it kinda sounds like a trans issue possibly.
idle? i get those harsh move once in a while when i first start the car, both goin forward and reverse,
Are your mounts original?
These mounts are typically good for 50k tops. That very well may be your issue. Front and side in particular and probably the rear with the miles you have.
