Wheel alignment problem
Old May 19, 2008 | 12:46 PM
juice2000's Avatar
5th Gear
Can some wheel expert help me-
I went to Costco to get the wheels balanced and rotated on my 2000 TL. He said that he cannot rotate them because front tires are bad and I need to get alignment checked. Visually the tires/treads look ok. Is this a common issue and what causes it? What is the best next step?
Old May 19, 2008 | 12:52 PM
02TLSU's Avatar
bad alignment and possible bad camber, take it somewhere that does alignments and they will fix both. Why costco?
Old May 19, 2008 | 01:45 PM
fsttyms1's Avatar
You say they look ok, and they say they are bad. Did you ask them to show you where they looked bad? If they say you need an alignment due to wear maybe you do. Have an alignment shop or them (if they do it) check and fix the alignment.
james357
Feb 13, 2016 02:37 PM
Zonian22
Nov 14, 2015 01:20 PM
GhostTL09
Sep 19, 2015 01:57 PM
Zonian22
Sep 2, 2015 08:19 AM
