What to Look For
Old Feb 3, 2009 | 11:59 AM
sleeper36's Avatar
8th Gear
What to Look For
My 03 TL Type-S is running good. Can anyone give me any advice on things to look out for or things to make sure I check along the way before they go bad. I don't want to run into major expense repairs if I can be proactive now and correct them.
Sleeper36
Old Feb 3, 2009 | 01:41 PM
indoMFP's Avatar
What your problem is?
1. Welcome to Acurazine...
2. Will need a bit more info on your car
3. Different environments/driving conditions will cause things to break/need maintenance at different times.
4. Use the 'Search' function... a lot of stuff you can ask us here or do a search for them and you can answer your own questions with the advice of several loyal Acuraziners.
Old Feb 4, 2009 | 12:53 PM
sleeper36's Avatar
8th Gear
Thank you. Well, I live in Sunny California. I only drive about six miles to work one way, and I'm the second owner of the car. I take surface streets and avoid the highway. I just want to be proactive before something break.
Thanks again,
Sleeper36
