Weird sound from driver side rear
Old Apr 15, 2012 | 11:05 PM
FLASH11's Avatar
over the weekend i installed new struts and shocks. after finishing and driving it, there's a slight clunk coming from the driver side rear wheel. should i check to see if the top of the struts are tightened? it sounds like its coming from the bottom which i searched and people said it could be the endlinks. we didn't take the endlinks out when we did the switch because the bolts wouldn't come out, they just kept spinning
Old Apr 16, 2012 | 10:11 AM
01tl4tl's Avatar
sway bar end links may have been damaged while extra load was happening during install
if it does it over bumps that is your first place to look
Otherwise YES always go back and ck all the bolts
things tightened when it was in the air are not the same when back on the ground
how did you put them together?--an air gun to tighten main nut on top of strut?
csmeance
Jan 7, 2026 06:25 PM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
JnC
Sep 11, 2015 06:06 AM
08 NBP TL
Sep 8, 2015 08:49 PM
