VSA issues
VSA issues
After exiting the highway and slowing to a stop, I heard this weird humming sound and the triangle (!) light blinking. The sound and light kept coming back after giving it some gas or stopping. Other than that, the light doesn't come on when driving normally. If I disable VSA, there are no issues whatsoever.
I've read a few threads, and some recommended replacing the wheel speed sensors, but all the threads stated having the lights constantly on. This is not the case on my car, but can it be related? I did change the upper control arms a few weeks ago. Any thoughts?
Here's a video of the light blinking and humming:
http://youtu.be/w6nZR3E8UQA
go back and find the loose or damaged wire that occured during the control arm job
sometimes you can fix a wire--sometimes its sensor time
no need for all- just the bad one
get codes read at parts store- should give something for speed sesor
Thanks a lot. I'm leaning towards the driver side being bad since I also had replaced the wheel bearing. The code wouldn't show which side, would it? And is it worth getting OEM or aftermarket is fine?
whichever is cheaper and more convenient for you to get
Many dealers support azine and offer great discounts that may equal aftermarket $
see Vendor list at top right of pages
make some phone calls is my suggestion,,a sensor is a sensor for this part
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
