vibrations?
Old Dec 1, 2006 | 02:14 PM
poohlikeshunny's Avatar
Money is funny.
vibrations?
I have just chnaged out the plugs and changed the oil and now my car is running a little rougher during idle...i'm at 125k..any advice?
Old Dec 3, 2006 | 11:56 AM
Hitlayers's Avatar
I am having a similar issue with my 99', and I thought it was the spark plugs also, didn't change them yet but since you did and you still have the rough idle what else should be changed??
Old Dec 3, 2006 | 07:24 PM
Bob_F's Avatar
Did you do anything other than the spark plug and oil change?
There are a ton of things that can cause idle problems.
Maybe you inadvertently fouled one of the new plugs during the installation?
Another possibility is that one of your plugs is defective or has a cracked insulator.
Bob
Old Dec 4, 2006 | 12:20 PM
Money is funny.
plug and oil and coils were all i did, I was rather careful with everything so i don't think I fouled anything up...I noticed now it fires up a little more hesitantly in the mornings now that it's colder, but it never used too...
Old Dec 4, 2006 | 05:44 PM
dreem1er's Avatar
deal with it
it only after you changed the plugs that you noticed the vibration..........my 03 tl was a little rough to, but was a bad motor mount............
Old Dec 8, 2006 | 08:17 PM
Money is funny.
How much are mounts? And how do you know which one is bad? I was thinking it could be the mounts to given it's a 2000 with over 125k now...the plugs were actually done about 2000 miles ago, I just didn't remember noticing it until one day I turned my music off (which is usually louder than the rest of the car
Old Dec 8, 2006 | 08:23 PM
Bob_F's Avatar
Did you use OEM spark plugs? Some plugs don't work as well as the OEM plugs.
Bob
Old Dec 8, 2006 | 09:09 PM
Money is funny.
i used ngk iridiums from napa auto...but stock is ngk too, right?
Old Dec 8, 2006 | 09:11 PM
Money is funny.
I have also noticed lately that when the tach is 1500 rpms or below, it vibrates a little more han it used to. Kinda like when you are trying to start moving from first gear in a manual but don't give it enough gas. Enough to get it going, but not smoothly.
Old Dec 18, 2006 | 12:25 PM
abernardi's Avatar
Rough Idle Too!
I just had my 2002 TL 90,000 tune up at the dealership. They found two cracked engine mounts and replaced them. I drove it home and the tranny started clunking and surging when going into reverse. Took it back the next day, the tranny took a dump, they replaced it under warantee , but since then, the idle is rough. Very annoying.
Now I did notice something like this before the tune up, once every day or two when I'd pull to a stoplight, it would seem to idle too low and vibrate. I'd tap the pedal and it went away. But since the work it is constant. I don't feel it so much when I'm in drive, but in nuetral and park, it's very noticable, in fact it's nerve wracking. The dealership took it back, looked for cracked sparkplugs, adjusted the valves, even cleaned the injectors...still the rough idle.
Now they're telling me that all TL's do this and they sat in several of the TL's they had on the lot and they felt the same vibration. This can't be right.
Anyone?
Old Dec 19, 2006 | 03:06 PM
2000tl32's Avatar
Which engine mount goes bad, I have a 2000 tl, and I am too having this problem of viboration.
Old Dec 19, 2006 | 04:34 PM
2000tl32's Avatar
anyone
Old Dec 19, 2006 | 04:44 PM
fsttyms1's Avatar
Front and side
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
