Very strange headlight problem
Old Dec 18, 2014 | 06:52 AM
TLSAZ's Avatar
4th Gear
My girls tl started this strange thing this morning. When u turn on the headlights the high beams come on as well but they are very dim and the left headlight flickers and is very dim aswell. Anyone run into this issue before?
Girlfriends tl headlight issue
Old Dec 18, 2014 | 07:00 AM
TLSAZ's Avatar
4th Gear
Also the high beam dummy light stays on and is very dim
Old Dec 18, 2014 | 10:58 AM
TLer trash's Avatar
I'd check the grounds first. Does your car have daytime running lamps?
Old Dec 18, 2014 | 11:28 AM
ErickUa5's Avatar
Mr.Helpful Diagram
Thats the same thing I thought, This may be a canadian TL.
To the op: If you have aftermarket HID setup, try swapping ballast from left to right side and see if the problem follows. if it does its your ballast.
Old Dec 18, 2014 | 03:04 PM
01tl4tl's Avatar
OP registers as Arizona so probably a USA car
The high beams- do they go on and off with their switch or stuck ON at all times with the lows?
Might be in the stalk-switch, or a weirdness in the relay and low beams
Low beam flicker is likely time to replace your aging HID system - luckily aftermarket is way cheaper and better than stock parts,
A full setup of 2 new ballast-ignitor/invertor and 2 new bulbs of very good quality for $60 to 100 or $200 depending on maker and seller
see any of the 100 current `low beam` threads for more help
Any moisture inside the lens of lights after rain or washing? that's a ballast killer
Old Dec 19, 2014 | 08:50 AM
TLSAZ's Avatar
4th Gear
If she turns the high beamsi believe only the one high beam gets brighter. I will check tonight and get back to you. Thank you guys so much for your help.
Old Dec 19, 2014 | 08:51 AM
TLSAZ's Avatar
4th Gear
and no the car does not have day time running lights
Old Dec 19, 2014 | 10:16 AM
01tl4tl's Avatar
its possible the high beam bulb is simply worn out, but more likely to suffer a ground wire issue
The High beams are plain 12 volt bulbs, not hid like the low beams = cheap!!
TLrascal
Aug 3, 2018 11:00 PM
Robospinner
22
Sep 24, 2015 08:47 AM
MistaWet
Sep 15, 2015 08:26 PM
kareshi
Sep 3, 2015 03:38 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
