under 60k, change ATF?
my TL has under 60,000 miles and i have no knowledge of the ATF being changed... change it or dont change it?
Also, if so, which is the best fluid to use? many say the original Honda ATF but now im hearing otherwise
YES YES YES change the fluid now,,
honda doesnt sell the original stuff, new formula is DW-1
and is in use by several members who report smoother shifts
with low miles I would do a full fluid changeout- plus replace the external filter and maybe clean the selenoids
the system holds 7.3 qts total
but you can only get 3-3.4 qts to drain at one time, then you drive a few minutes using each gear to push fluid forward in system and drain again,,
repeat this until new fluid is all that comes out,,
often called a 3x3 meaning 3 qts 3 times but its really more than 3 qts ---buy appropriatly- expect $10 a qt at honda
the dealer 70-90 dollar `flush ` is nothing more than a gravity drain and refill of 3-3.4 qts
Same thing you can do at home for the cost of fluid!
this job is easier than an engine oil change, as there is no filter dripping down your arm
(there is an external atf filter but not part of discussion here)
these trans tend to act up around your mileage
so we are suggesting get on a fluid program now- with the new- better fluid from honda
I would take a 3 oz sample of the old fluid during drain for analysis by blackstone labs
that will tell if wear is normal or anything you need to be concerned with
20 bucks for peace of mind is a bargain, or finding a problem now....
the oil jet kit is held in by one bolt on the side,,12mm head iirc
then it pull it straight up
using the normal atf filler hole is WAY faster than trying to use the dipstick tube
but dipstick tube will work,, in case the oil kit refuses the budge
to get it all changed by acura gravity drain-refill-drive few minutes using each gear-
either 9 or 12 depending on how you read the book
total capacity is 7.3 but only 3 to 3.4 will drain out at a time, the rest hides in the torque convertor and gets pushed out and thru system to drain when driven
Use of each gear forces fluid thru everything causing out with the old in with the new
option: use the method with engine running and pumping out old fluid as you pour in new
See vid of accord, often posted on trans threads here..ignore part of adding anything but honda fluid at the end- thats for other cars= not our trans!
I to am concerned about the transmission recall for my 2003 3.2 TL. I bought it used in 2006 and have ~88k miles. I called the 800 # to find out if I have a rebuilt transmission or an oil jet kit or both. I read about the blue bolt heads and I have them, but I can't tell if I have the kit. The 800# could not tell me if I have the kit. Can I see it from looking at the engine from above?
look at top center of trans for a large bolt with ATF stamped on it
if you see that- its got a post 05 case and kit was moved inside trans
otherwise a funky thing with a small hose running off the the side will occupy that same hole--thats the jet kit
blue bolt heads means replaced by acura warranty trans
dealers can often give more info than the 800 people
frank
there are directions on here for the atf filter change- its not a simple screw on--
c'mon where would the fun be in that!!
mixed old/new fluid always happens,,choose to do 1 or 2 drain and refills then go for it!
expect up to 3.4 qts each time, so buy 4 qts per draining
swoosh
there are reports of increased stiffness to the shifts with redline
If you are young and dont care about smoothness, no sweat
Some of us have back/neck injuries and want the absolute smoothest transition between gears--anything else feels like a 2x4 slamming you with every shift- not fun
takin care of Business in
swoosh
with redline (i have 5k miles since the first drain and refill in) the shifts are smoother....only the first cold shift in the morning is kinda harsh....
again am using type f racing all the way and not the D4....
swoosh
dude this is 2011....use GOOGLE....embrace the Internet....
but here will help you out with it:
http://www.lmgtfy.com/?q=Transmission+solenoid
01tl4tl is a genius....he is a Acura Certified Tech....so what he says, I listen
I am on the forums a lot and try different things....I have redline in my system and I am loving it
here is the link to my thread: https://acurazine.com/forums/3g-tl-2004-2008-93/redline-my-system-820509/
There's also one report of trans failure with the new stuff. I still think type f, or racing atf is the only way to go. I base this solely on the information in the redline racing atf thread. It's a lot of reading, but I think every acura/honda owner should read it before choosing a trans fluid. If I understand it correctly, the new honda fluid is basically mercon vi. It probably won't oxidize as fast as the z1, but it's a low viscosity fluid with lots of friction modifiers for a nice smooth shift. I believe the change to this fluid was another attempt to gain tiny improvements in fuel economy, with little regard to transmission longevity.
Especially added to an already worn trans.
disclaimer: I am not an acura tech!
What I know specific to the TL was gleaned from the many pages of acurazine! (and the owner book)
You too can know everything I know about this car
The other mechanical stuff comes from growing up around race vehicles-planes-boats-cars,
and being a pilot, scuba diver, yadayada....
at the end of your life,,it was all just stuff, but what great toys they were!!
So, from what I have read here, taking your TL to an Acura dealer for a transmission service does not mean they drop an oil pan and remove the filter, refill and do a few cycles to get old oil out of the torque converter, etc.?
Excuse me for my unfamiliarity with Acura transmissions, I'm an old Chevy turbo 400 guy.
Thanks.
Thanks.
Thanks.
Thanks.
"they use a machine to suck all the old tranny fluid out of the car and put new fluid in....no driving around in different gears....hence I would recommend doing the flush yourself....
care to elaborate or post the link of the thread when you create the thread....?
