Turn Signals not working, not found in other threads!
So I have a 2003 tl-p, and recently the turn signals stopped working on both the inside and outside of the car. I checked the fuses and replaced the flasher relay, however the problem persists. There is no clicking sound from the flasher relay when I engage the switch. I do not want to buy a new turn signal switch if I do not have to, is there any way to tell if it is in fact the switch or not?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
install the spare fuse of that rating and test again,,spare is stored in fusebox
never think you can tell one of these micro fuses is good without a test meter
is there power at the fuse port?
you can buy signal parts used if needed,, dont hear about them wearing out --
but it can happen,, if you are a really good driver and signal all the time!
is this since you did the switchbacks? ck all the ground wires for those
Ok thanks I will check those and report back, the switchbacks have been done for over a year so it shouldn't be them. However the led switchbacks do seem to need replacement more often than I would have thought, they flicker and go out after only like 5-6 months.
sounds like bad ground to me
so here was the problem..checked all the fuses and the ports they went into. checked the ports the flasher relay went into, & turns out that the flasher unit that i had purchased from the store was faulty. sucks, but at least it wasn't anything too problematic. thanks a bunch for your help bro.
mada51589
05-03-2022 08:54 PM
