Trunk problem - 99 TL
Old Feb 7, 2009 | 08:46 AM
dougvf's Avatar
5th Gear
I opened my trunk and now it will not close. It seems the latching mechanism will not engage when I close the trunk. When I press the trunk open button on the door or use the remote, I don't hear any noise like I used to. Is there a fuse for this? I looked in the book and it doesn't show a fuse. The manual pull in the truck doesn't do anything else either. I pull it but it doesn't do anything on the lock itself, it seems like there is slack in that cable at the lock which, to me, seems like the lock is open so it doesn't "open it again".
Any thoughts?
Old Feb 7, 2009 | 10:03 AM
fsttyms1's Avatar
Try to manually close the latch piece with it open (with a screw driver or something) and see if you can get it to move. There have been a few who have had to replace the latch.
Old Feb 7, 2009 | 01:59 PM
dougvf's Avatar
5th Gear
I tried that but it will not stay "latched" It seems to be stuck in the "open" position. Any other thoughts?
Old Feb 7, 2009 | 02:14 PM
MurdaZ's Avatar
i had to change the latch on my 02 tl, wouldnt stay closed, was like a 50 dollar part and easy to swap
Old Feb 7, 2009 | 04:14 PM
adamlee05's Avatar
Thread Police Chief
probably the trunk fairies playing games with you
Old Feb 8, 2009 | 01:57 PM
dougvf's Avatar
5th Gear
I guess I will try to replace the trunk lock. It looks like I can get one online and it isn't too expensive. I already took the old one off and it was easy. Since there doesn't seem to be a fuse for the trunk lock, I'm not sure what else could be wrong.
Old Feb 9, 2009 | 09:40 AM
rattmann316's Avatar
try to loosen the striker a bit. is it stuck open or closed (the latch)
Old Feb 13, 2009 | 05:55 PM
dougvf's Avatar
5th Gear
Here is the final fix. I ordered a new trunk lock ($60.00 plus shipping) and replaced it and it now works perfectly. It looks like the lock just went bad. There must be some sort of
Solenoid in the lock that went bad.
Old Feb 2, 2010 | 12:40 PM
AcMan24's Avatar
Dougvf... Where did you order the trunk lock as I need the same part? Thanks!
mada51589
Jan 9, 2025 04:40 PM
spoiler900
May 25, 2016 10:16 PM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
brandnewcolony
Sep 12, 2015 10:39 AM
