triptronic issue
Old Nov 19, 2011 | 07:37 PM
hondakid23's Avatar
triptronic issue
what's up guys quick question. on my car when I started up the first 10 to 15 minutes when I use the trip Tronic it's pretty stiff seems like I have to use a lot of force. any suggestions
Old Nov 20, 2011 | 04:52 AM
01tl4tl's Avatar
ck the lube on shifter assembly under car
SS works off microswitches under the shifter, spill anything in the cup holder area?
changed the atf recently--within last year or 2?
car year and miles? trans replacement history,,any other background?
Old Nov 20, 2011 | 04:54 AM
01tl4tl's Avatar
hows it shift if left in D5? smooth, jerks between gears, shudders,,slips??
why are you using SS anyway?
it just encourages high rpm downshifts, creating heat, causing excess wear on 2nd and 3rd gear clutches--makes for early trans death
Old Nov 20, 2011 | 09:16 PM
hondakid23's Avatar
2003 with 123,750 miles. but that makes sense because I have spilled stuff inside the cupholder
Old Nov 20, 2011 | 09:17 PM
hondakid23's Avatar
I also changed the automatic transmission fluid last month
Old Nov 21, 2011 | 08:11 AM
hondakid23's Avatar
car runs good on D5 no slipping
Old Nov 21, 2011 | 11:41 AM
01tl4tl's Avatar
thats good news!
you used what atf? hondas new dw-1? a 1 drain and refill= 3.4qt change?
or more times?
did you recheck the fluid level per book??? the trans drains between 3 and 3.4 qts,,add 3 and you may be low!!
15 minute freeway cruise from cold- then immediatly ck. parked, engine off,
fluid level shows `between the dots`
as fluid temp changes, so does the indicated level
the 'Ol Spilled soda in the cupholders trick,,been there
get some crc electrical spray contact cleaner
cheater method- shoot liberally thru shifter plate and pray
Correct method: as the switches are located on the underside of a plastic plate beneath the shifter--remove side console- provides access to switches
spray clean them- 3 total- ck for arcing or melted appearance (if system doesnt work or acts funny)
not too expensive, getting to them is the major labor part of the job
diy section has help on panel removal
Old Nov 21, 2011 | 02:57 PM
hondakid23's Avatar
thanks alot for the help guys
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
