Trans drain plug is being a PITA
Today I bought oil, filter and 3 qts do start the 3x3 flush. Did the oil change fine. Go to remove the trans FILL bolt and it was a BIATCH but I got it, placed it back in finger tight, move to the drain plug and it wont budge. I am reluctant to tap the trans case with a hammer even if I do it lightly, Any other suggestions? I will admit I was on jack stands today because the lift was taken and I am going on a trip tomorrow so I wanted to get it done before so I couldn't get any great leverage but it shouldn't be THAT tight
2002 TL-S 160K
2002 TL-S 160K
Breaker bar
Try torching it first then . I think if anything the drain bolt would fail before the trans housing but we all know the Honda transmission is made of glass so maybe you're on to something
![Bite Lip](https://acurazine.com/forums/images/smilies/bitelip.gif)
Mr.Helpful Diagram
I just kick the ratchet with some working boots, works 100% of the time.
Breaker bar is safer as long as the car is safely jacked up or on a lift.
Put your back into it and use some more force.
As for using heat, or taping on it with a hammer think about it for a min, the trans is getting well over 300deg, heating the bolt a little isnt going to hurt it, and as for tapping on it, it sees far more vibration and shock from normal use/driving than tapping on it with a hammer would do. Also, think about how much force you needed to break the fill bolt loose, you didnt break the case then did you?
^^^ Yep, first time I removed it I gave it a good kick while sitting at the front of the car. IMO, this is totally safe if you still have the wheels on.
