Tranny question for anyone
I just put a remanufactured tranny into my 2002 tls. It shifts just fine, but I have noticed that my gas pedal is a little stiff. I also noticed that I do not have the quick response from the gas pedal I used to have. Is this normal for new transmissions?
Originally Posted by fla-tls
No. Check the throttle cable to make sure it's not twisted or bound up. They probably unhooked it while removing the tranny.
Originally Posted by Blazin_TL
the throttle cables are mounted on top of the throttle body on the drivers side under the hood.
Registered User
Originally Posted by greentypes
Someone else mentioned that the ecu may be programmed to respond differently on the new tranny. Does this make sense to you.
Pham Alvan
03-16-2016 09:17 AM
navtool.com
31
11-16-2015 08:30 PM
