tranny isue AFTER rebuild
had the tranny re-built in my 2003 A-spec in March.
Since then it has been difficult to get it in drive particularly D5.
Once the dash light confirms I am in drive, it works perfectly but it takes a lot of dicking around with the shifter before the D5 indicator light comes on; and the problem is getting worse. There is also a small leak but I assume that's unrelated.
For reasons that I'm not going to go into in detail, I refuse to take it back to that jerk.
In the city I live in, a high % of transmission shops are rip-offs, so I would like an opinion from this forum as to whether this sounds like a big fix or some relatively minor adjustment? I am definitely not going to invest in another re-build; I'll scrap it first.
Mostly likely something to do with the trans Range Switch or Trans cable adjustment.
Check for loose connection at range switch, adjust/replace if necessary; loose cable at shifter (occupant cabin) and trans lever (engine bay), adjust if necessary.
I actually have the same problem but mine is in D3 and N. D5 would be a more serious problem in terms of annoyance. I have a leak as well, the underside of my trans is always wet (and something burning when I shut off my car in the garage). The only fluid I'm having to constantly replace is P/S fluid though.
I think my shift cable is out of adjustment and the problem started when I had my trans rebuilt. I just think these mechanics are in a hurry to get things slapped back together and they don't adjust the cable properly.
(offtopic)
And I totally agree, most mechanics are assholes. I really f'n HATE them. A labor rate of $80-$110 per hour on average, when the actual mechanics themselves get ~$25 per hour is just ridiculous. It's complete douchebaggery and it's my life mission to make all these big box mechanic shop types (and dealers) go out of business.
(/offtopic)
(offtopic)
(/offtopic)
(offtopic)
(/offtopic)
Which solenoids are you referring to?
My issue is with the shift selection - I have to screw with the shift selector a little to get the D3 light to come on and same with N. When in N the gear indicator (normally red in the instrument cluster) usually turns off and the reverse gate deal freaks out (clicks rapidly in the center console).
Chojun (11-09-2015)
The Machine
11-11-2015 03:00 PM
urtalkin2sonny
15
11-04-2015 07:34 PM
