Tranny Failure Thread
Old Oct 31, 2010 | 10:36 PM
  #3001
deploytosave's Avatar
4th Gear
bought my 01 CL-S with 152k on the odo.. im guessing its atleast been replaced once.. any way to tell if it has been?
Old Nov 1, 2010 | 03:17 AM
  #3002
01tl4tl's Avatar
sure-
the easy way is open the hood and look at bolts on transmission
if the bolt heads are painted BLUE thats an acura warranty unit
If the external oil jet kit is in the normal atf filler hole on top center of trans -you have a pre 2005 replacement
after mid 2005 a new case was used with that part moved internal and better oil passages were cast. Those have a large bolt with ATF stamped on it-thats the filler hole
call acura and register as owner- ck recalls and ask warranty history
1- 800 382 2238x5 need cars vin
Old Nov 1, 2010 | 03:18 AM
  #3003
01tl4tl's Avatar
this is the TL forum, you will get more info on the CL threads.. specific to your model
Old Nov 1, 2010 | 08:08 AM
  #3004
dudeinaTL's Avatar
Originally Posted by qualityeye
I had the same issue. I put about 15K in 15 months on a rebuild and then it failed (I had a 12/12 warranty). The worse part about the way it happened to me was there were no signs the tranny was going like the first time. It just died on me while driving (like two hours away from home). I have about 2K on the new rebuild and so far no problems. I'll be done with this car soon though. I already have a replacement car and I figure since I've spent so much on trannys I have to use the car a little more before getting rid of it.
Yeah I'm done with this car, even though it's only been 9 months since I first got it. Good thing is my warranty is still valid.
My plan once the tranny originally blew up was to dump the car when the rebuild's warranty was up, no matter what condition. The fact that it's shot early actually buys me some extra time to look for a new car though.
This car / Acura has shown me no love, so no need to show any in return.
Old Nov 1, 2010 | 08:05 PM
  #3005
4th Gear
thanks for the response and tip, still figuring out how to navigate this huge site!
Old Nov 2, 2010 | 09:32 PM
  #3006
01tl4tl's Avatar
that bar at the top of pages has all the forum links,
and the list at bottem of pages are sub forums, not directly related to one car..things like wash and wax
Old Nov 15, 2010 | 12:21 AM
  #3007
xangvang's Avatar
hey u guys i am new here but having problem going into reverse. i have a 2003 cl type s 6mt. all the gearing are fine an d normal but the reverse seems to b block or something i just can't go into it has anyone have this problem?? help!!!!!!!!!!!
Old Nov 15, 2010 | 01:47 AM
  #3008
01tl4tl's Avatar
this is the gen2 TL section and only the people who did an engine/trans swap will be found here
Try posting in the CL section..
for basics: ck clutch master cyl resivor level--has it dropped?
if so, look behind rubber dust seal on clutch slave cylinder- is there fluid leaking out--you need a slave cylinder
thats a common failure with normal use- and causes loss of pressure to operate the clutch
Try giving it 2 pumps to build pressure in the line, then try reverse--
does that make it go in easy?
Old Nov 18, 2010 | 12:09 AM
  #3009
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
http://www.youtube.com/watch?v=RpQMU...eature=related
http://www.youtube.com/watch?v=gwN1OOs8E2U
http://www.youtube.com/watch?v=j4i7HsX40wQ
Old Nov 18, 2010 | 12:10 AM
  #3010
Old Nov 21, 2010 | 11:09 PM
  #3011
dudeinaTL's Avatar
More info for the curious...
https://acurazine.com/forums/2g-tl-1999-2003-98/rebuild-m7wa-b7wa-tranny-767823/
Old Dec 8, 2010 | 08:53 PM
  #3012
Hudd's Avatar
New owner of used Certified Acura TL love the car. The only thing that I don't like is it downshifts hard and 40mph and then at 20mph. Took it in for several other things that the dealer fixed but they said the transmission was fine. I just figured a luxury sedan should shift smoother than my wifes Corrola. It makes me a little uneasy with it's future and it already has over 60,000 miles. Thoughts - normal or not normal? I don't baby the car by any means. highway travel is normal just the in town stop and go.
Old Dec 9, 2010 | 10:38 AM
  #3013
01tl4tl's Avatar
go back and ask the service MANAGER if the Head tech can take a quick ride with you to observe the trans issue
As a new owner they might help you out--especially a CPO car!!
register with acura care 1 800 382 2238x5 as owner
Old Dec 9, 2010 | 04:24 PM
  #3014
bozzchem's Avatar
My second one croaked after the warranty expired so paid $2500 to have it rebuilt. At least this was rebuilt by my brother's father-in-law so if I have any issues I know where to go and won't have to deal with a bunch of BS from the dealerships.
He indicated that he rebuilds a LOT of these and did indicate some of the parts used for my rebuild are superior to the stock parts. I guess I'll find out.
Old Dec 9, 2010 | 05:03 PM
  #3015
dogbane's Avatar
Tranny failure....
Unfortunately I find myself requesting some information. Love the list, a lot of knowledge here. I just hate asking for help.
I am (or was) the proud owner of a 2003 TL. Worked my butt off to get it 4 years ago with only 32500 miles on it. Only after buying the car did I find out about transmission issues. This past Monday I was told by the local Acura dealer that my tranny is toast and needs replacing. Again, a 2003 TL that just turned 79k miles just under 7 years 9 months after the original purchase. I was told it is out of warranty and does not fall under any warranty extensions. The VIN is outside the specified parameters for the extended warranty.
The cost for replacement: $3769.31.
I mentioned to the service tech that I thought Acura should cover the cost. He said he would submit my request.
Long story short, Acura came back saying they would cover 35% of the cost, me 65%.
Am I getting burned here or am I fortunate they made this offer?
I understand from a friend that works on transmissions (and is well aware of Acura’s problems) that the PCM and fuel pressure regulator should be replaced as well. The dealer’s service advisor said no, that’s not part of the replacement deal. I have a technical repair bulletin dated 02/05/08 that reads different.
What should I do? Is there anyone at Acura that I can contact? A hot line somewhere? Dealer said I had 48 hours to decide.
I just cannot fathom a $32000 automobile, less than 8 years old with 79000 well maintained miles having this problem. I formally owned a 1991 Integra and put 250,000 miles on it with no problems at all. To say I’m disappointed and angry is the understatement of the year.
Can someone help with some advice and/or information?? It would be much appreciated.
Thanks for your time.
Kevin
Old Dec 9, 2010 | 11:58 PM
  #3016
01tl4tl's Avatar
you are out of VIN range for the extended warranty - that was just a number picked for the court case,, so they are working on Goodwill policy to help you out
read the last 4-5 pages of this thread for my post on obtaining goodwill
If you have history with the dealer by getting brakes or oil changes, bought 3 acuras from them etc,,that helps get the amount lower
on average recently its anywhere from 300 to 2500
Did you speak with he service MANAGER or just the service writer?
If you ask the manager for more help-thats who calls corp-they can often get the price lowered
Local places are getting 1800-2500 for a rebuild
the advantage of getting the acura unit is the new external case- which has better oil passages and moved the oil jet kit for 2nd gear internal
Old Dec 10, 2010 | 12:06 AM
  #3017
01tl4tl's Avatar
as for your care of the car and miles- you are what the acura techs call--
`right on schedule for trans failure`
anywhere after 60 is ready for the wearout issue
Did you ever change the trans fluid?
certain vins get a new ecu or pcm something -only included in replacement if called for.
a TSB technical service bulletin- is ony referance material for techs, not mandatory like recalls
Service writers are sales persons of repairs and parts,,their job is to make money for the company. The first offer is not alwys the last offer~
Most are not techs and dont look up details of things that you may have found digging around online,, or a buddy told you something...
you can speak with the acura rep to see if they will do better- go talk to the manager first..bad to jump over them without talking first
Old Dec 10, 2010 | 02:45 PM
  #3018
bozzchem's Avatar
Kevin
You are in my neck of the woods. If Leith won't take care of you and insists that you pay 65% for the price for a "new" tranny, PM me and I'll give you the information for the shop that rebuilt mine. This is the THIRD transmission in my TL-S with only 140K on it and I bought the damn thing brand new from Leith! Hell, if they'll only pony up enough to compete with the cost of a rebuild, I'd tell them to pound salt and get it rebuilt elsewhere. They are the ones who put my second tranny in at 25K miles. I flushed it with Amsoil at 50K and again at 85K. No dice. It still shit the bed.
Since I personally know the owner of the shop, I expect this to be the last tranny in my car.
My second tranny started slipping while still under warranty but Leith said they couldn't reproduce the slippage so charged me for the "diagnostic" and gave me the boot. I will never buy another car from them and will be highly reluctant to buy another Honda product based on the transmission issues I've had and hearing Don tell me how many of these transmissions he has rebuilt.
Expect the rebuild to run you in the $2500 range but Don stands behind his work unlike Acura.
Old Dec 10, 2010 | 05:09 PM
  #3019
01tl4tl's Avatar
sidenote: if acura dealer charged you diagnostic fee and stated PNF Problem not found- that will get you goodwill if failure occurs after limits- they did you a 100 dollar favor, believe it or not
They tried and cant find it now--the old story
boz: feel free to post name of good rebuilder shop- share good news!!
Also gen3 has done a lot of testing with redline and amz,,findings say go with redline to avoid probs..amz and the TL not the greatest fluid mix,,works yes,,but really helping our problem- you are better off with redline
see post by I Hate Cars for details on which of the fluids to use
He has eleminated 2nd gear shift shudder with that fluid and new pressure switches
On not buying another honda product,,just get a warranty~
we are driving what are now considered to be older cars!
doesnt matter what they cost you new,,cars are made cheap as possible
Old Dec 10, 2010 | 05:11 PM
  #3020
01tl4tl's Avatar
acura rebuilt unit comes with a 3/36 parts and labor warranty
Im not trying to sell you one--just putting out facts here
Old Dec 10, 2010 | 06:16 PM
  #3021
bozzchem's Avatar
Yeah, Acura will tickle your giggleberries and then leave them hanging when SHTF. I've heard over and over and over how I should have had my car towed to Leith and see what they'd do. Considering they were inept enough to miss the slippage on my last visit, I decided to just get the damn thing fixed properly. I don't have three weeks to dance on the phone with them.
Time is money and getting my car towed to them and then haggling vs. just getting it towed and fixed wasn't an option. I'm not going to spend days on the phone playing games with Honda/Acura. I want my car fixed and back on the road. That is the option I chose and other than the cost, I don't regret it.
Anyone who has been to an Acura (D)Stealer will understand why I declined to waste my time. There was no way in hell they'd do it for free and there was no way in hell I was going to pay to have them put a THIRD one in considering numbers 1 and 2 shit the bed. F them.
My brother's father-in-law runs a tranny shop in Raleigh, NC so I figured I'd just get the damn thing rebuilt properly without jumping through hoops.
While I will keep this car until it dies, it is the last Honda/Acura I will purchase.
Old Dec 10, 2010 | 06:25 PM
  #3022
bozzchem's Avatar
Who rebuilds it? Is it rebuilt with the same shitty parts that fail in the first one?
No offense, but no thank you. My first one went @ 25K. Second went @ 120K.
Screw that bullshit. I've got a Ford truck with double that mileage still rolling on the original tranny and I didn't pump it full of Amsoil changes at $150 a pop.
I personally spoke with a man who rebuilds these and he indicated they are junk. Thank God he doesn't rebuild them to stock specs but has figured out the stock tranny is crap and uses superior parts.
It sucks coughing up $2500 but it beats buying a new car or just waiting for your "rebuilt" tranny to leave you stranded.
Old Dec 11, 2010 | 01:34 AM
  #3023
01tl4tl's Avatar
acura has contracts with rebuilder shops across the country for all the returned warranty parts
Aftermarket has superior clutches- which is the weak part
but, one main problem is
you cant fit enough clutch plate disc-stacked- to handle the torque,
and the low oil flow to the area for proper cooling speeds the demise
the post 2005 case unit has better oil passages and improved life--thats a reason to get acuras IF its a good price and you plan to keep the car
If you have a place you can trust--go that way,, if already have a post 05 case~
Strange how some people have the worst luck and several failure while others never experience the trans issue
Old Dec 11, 2010 | 01:11 PM
  #3024
I heard something that the trans parts ether come from the US or Japan... (like the TC and the clutches)... - the Japanese ones are much more resistant to wear...
Old Dec 11, 2010 | 10:48 PM
  #3025
GnarleyMarley87's Avatar
98 2.3CL
I'm looking into purchasing a 99 TL with a bad tranny. How much am I looking to spend to get it rebuilt or replaced?
Old Dec 12, 2010 | 09:05 AM
  #3026
russianDude's Avatar
2500-3000 outside dealership, dealer will charge 4000+
Old Dec 12, 2010 | 11:19 AM
  #3027
01tl4tl's Avatar
99 4 speeds are pretty reliable units compared to later 5 speeds
as said above 2500 at local shops is your best bet
it may be as low as 1600 if not many parts are damaged and just needs clutches and a few things
the car is worth 4 grand on a good day for a 99 ( my guess based on falling prices)
so if you can get it for a grand as it sits,,bargain total
but chances are it needs more than trans- like the 105 timing belt water pump job for $1000+
ck hondas of the same price if you are looking for a reliable deal
Parts and mait are way cheaper for them
Old Dec 17, 2010 | 05:06 PM
  #3028
tcross's Avatar
FWYB
Just had my 2003 tl-s trannie fail. spent 3180 to get it rebuilt. should i sell the car after it gets rebuilt to avoid another trannie slip?
Old Dec 18, 2010 | 05:59 AM
  #3029
01tl4tl's Avatar
it should last another 50-100kmiles depending on how good a job the shop did
Drive it a while to be sure its ok- sell if you want..
but the cars total value isnt much more than you spent already- assuming 105 service was done too
keep it and enjoy
Any car is going to have problems,,some more expensive that others
Old Dec 18, 2010 | 07:40 AM
  #3030
yeah, 01tl4tl is right. If tranny was rebuilt properly there is a good chance (I'd say 80-90%) that it will last 70-100K miles. So its up to you to take your chances or not, also depends if the shop gave you any warranty. On the other hand, I was thinking, if you rebuilt tranny with Acura, its $4K and 3yr/36 warranty, if your other alternative is to buy a new car for 30K, then of course you better of (economically) spending 4K over 3 years. In 3 years your new $30K car will cost < $20K. But if you thinking of buying another used car, than you might be better of selling it
Old Dec 18, 2010 | 11:33 AM
  #3031
niju321's Avatar
i've always been unclear on this...but in 2/05 was the 99 case revised also? or just the 5 speeds?
Old Dec 18, 2010 | 01:23 PM
  #3032
01tl4tl's Avatar
the 5 speeds
the 4s didnt have the same internal space issue and are more reliable in general
Old Dec 18, 2010 | 02:02 PM
  #3033
tcross's Avatar
FWYB
I love the car dont get me wrong, but im in college and cant afford to keep spending 3-5 grand on a new tranny. the parents advised tht i get a diff car
Old Dec 18, 2010 | 07:01 PM
  #3034
01tl4tl's Avatar
should get 4-5+ years of normal operation from it with a little care
Whats a different car need?- timing belt- clutch, brakes etc
depending on what else has been done= maitenance is current and not going to cost 1 grand next week,,keep it if you like it
compare the cost to a different car with its many unknowns
Old Dec 18, 2010 | 07:04 PM
  #3035
01tl4tl's Avatar
with most cars going down in value each month about the same amount the payment was, the TL with a fresh trans and on maitenenace, is a bargain for the next 4 years
If it only goes down 1000 a year for what you have spent on repairs, and gets you thru school- with a potential to sell it for something at the end,,its a good deal
if its a rolling pile of rattling parts~ thats different,,if you can find someone who appreciates that a fresh trans ups the cars value
Old Dec 20, 2010 | 09:08 AM
  #3036
coach2010's Avatar
Hey dogbane, my tranny failed this past weekend after just passing 100k miles. I live in Raleigh as well, have taken my car to Leith, and am waiting on an adjusted quote (I haven't even mentioned the word 'Goodwill' yet). Did you request the name and location of the shop bozzchem had his work done at? Have you had the work done yet? Please provide any information about area shops that you can. Thanks a lot.
Old Dec 20, 2010 | 11:58 AM
  #3037
01tl4tl's Avatar
coach
the current warranty for most of us (`covered vin`) is 7 years plus 9 months from date car first sold or 109kmiles whichever first-
also there are some cars with odometer error (court case) get extra 5% or 114.5 indicated miles
You can call acura care 1 800 382 2238 x5 (usa cars) to see if covered, or look in your my acura account on acura.com
see diy thread list - it has all the vin list for different recalls and warranty extensions
Good luck on getting that phone call that says.. Your car will be ready in 5 days, please come in at 3pm to get a loaner car~
Old Dec 25, 2010 | 12:54 PM
  #3038
duffduffxx's Avatar
Has anyone seen this thread?
The 3G TL's had this problem and the trannys were very similar.
All you have to do is replace the 3rd and 4th gear transmission switchs, do a 3x3 redline flush and results so far have been good.
https://acurazine.com/forums/showthr...=729149&page=5
Old Dec 25, 2010 | 05:11 PM
  #3039
01tl4tl's Avatar
there are some gen2s trying that procedure now
the switches and selenoids idea came from us~ acura was allegedly supposed to replace them with warranty trans exchange but it seems that many were not done
the redline racing atf fluid idea from gen3s `I Hate Cars` who is a real mechanic--
not just a parts changer,, a person who rebuilds pieces of cars and understands inner workings..
Dont get that guy started on the properties of different atf brands...
Old Jan 10, 2011 | 03:46 PM
  #3040
2000tltranny's Avatar
I have a 2000 tl with 85k miles. I noticed a slippage in 2nd - 3rd gear. I did the recall 3 years ago and they installed that external kit. Being ten years old that extended warranty probably wont apply any longer. What can I do to save the tranny - it only slipped twice so far? I have only driven it once since the slippage. Is it to late to save the tranny?
