tl 1999 tranny issue special
Hi people i am new here , hope to meet ha few people , ok just both my tl 1999, 250000 km very clean but the tranny here is the thing , lets say i put the car at drive , till there everything is ok after when i press the gaz in the mddle between the 1 st and 2 nd gear its long to shift and the 3 rd gear goes in right away to fast and it kicks ha little bit . . . but when i press the gaz slowly calm well the tranny shifts very good . . . ?????? , now the oil is seems to be brown could i changed it could it do ha difference ? .
[quote=GREEKBOY;13026265]Hi people i am new here , hope to meet ha few people , ok just both my tl 1999, 250000 km very clean but the tranny here is the thing , lets say i put the car at drive , till there everything is ok after when i press the gaz in the mddle between the 1 st and 2 nd gear its long to shift and the 3 rd gear goes in right away to fast and it kicks ha little bit . . . but when i press the gaz slowly calm well the tranny shifts very good . . . ?????? , now the oil is seems to be brown could i changed it could it do ha difference ? THANKS EVERYONE
fluid is supposed to be red or pink
fluid thats brown is burned and not lubricating
you can try a 3.5 qt drain and refill but its a band-aid at best now
thats a lot of kms ona TL trans if it makes you feel better!
when you press the gas slowly it allows the clutches to grip and hold rpm to accelleration
when they are worn and you ask for more power and grip--they slip, the rpm goes up, the trans bangs into gear etc
You could try to change teh fluid to see if it helps but there is no guarantee that it will fix the issue.
GREEKBOY (06-22-2011)
snorf
11-04-2019 06:44 AM
mugen_kid
11-13-2015 10:38 PM
