Tires
Old Mar 27, 2006 | 10:49 PM
chilifrost's Avatar
Question Tires
What makes tires wear out from the inside?
Old Mar 28, 2006 | 08:50 AM
fsttyms1's Avatar
Toe or camber. Most times out of 10 toe is the cause for tire wear on the inside. Get an alignment
Old Mar 28, 2006 | 11:35 AM
chilifrost's Avatar
Got an alignment from acura a few months ago? What else could it be?
Old Mar 28, 2006 | 11:59 AM
fsttyms1's Avatar
They didnt do it correctly what i listed is th ecause of it and thats alignment related. If it was tire pressure it would be either wearing in just the center or both the inside and outside of the tire
Old Mar 28, 2006 | 12:14 PM
snowman81's Avatar
Sippy Cup (x2)
Yeah, more than likely toe. Had the same problem and didn't notice until after a 2000 mile trip. It's possible the wear was from before you had the alignment done if it was just a couple months ago.
Old Mar 28, 2006 | 08:38 PM
chilifrost's Avatar
Yeah I think it was, would an alignment help if it was done after the tire started wearing from the inside or it will keep getting worse nomater the alignment? Assuming the tire will follow the uneven tread.
Old Mar 28, 2006 | 08:57 PM
fsttyms1's Avatar
U can get an alignment but the damage is done. they will tend to wear faster now in that spot. I would still get it redone to slow the process though
Old Apr 11, 2006 | 09:12 PM
ButtAhZ's Avatar
ALso depends if you slammed your ride, my tires shave easily in the inside cause of my drop. I've already aligned it with the dealership and they also tell me i need a camber kit bad. So usually if it is wearing in the inside and your ride is lowered u need a camber kit!
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
DidiBob
Jan 4, 2016 12:41 PM
Robospinner
22
Sep 24, 2015 08:47 AM
CostcoFanAUS
Sep 18, 2015 06:05 AM
fallacy
Sep 4, 2015 10:15 AM
