Timming belts kits help
Awhile back i seen a dealer on this site offering timming belt kits deal. are they still around? I check ebay and found this kit
http://cgi.ebay.com/ebaymotors/Acura-TL-Timing-Belt-Water-Pump-Kit-2000-2003-TL-S-/300449579953?pt=Motors_Car_Truck_Parts_Accessories &fits=Make%3AAcura|Model%3ATL|Year%3A2002&hash=ite m45f430c3b1
What do ya think? is there a better deal out there? Thanks for reading
Timing Belt Refresh (& more)
I literally just finished my timing belt replacement activities yesterday with great success (thanks to the Acurazine crew). For the parts I used G1 Parts in Texas (near Houston) which had great service, awesome prices, and free shipping when ordered on-line. Here is my parts list that was used for my 2002 TL Premium:
(note that G1 Parts only sells Honda Parts which works well for us since all of our TL parts are universal with Honda vehicles )
Remember to not over-tighten the PS Belt (read a few posts about noisy PS pumps after changing the timing belt) or you may have another $300-$500 PS pump investment when the timing belt is changed out.
Also, don't forget to drain the antifreeze within your engine block before digging into water pump. (avoids a bigger mess when you remove the water pump) For security purposes you may want to purchase a replacement bolt and washer as my bolt turned to mush due to age and the valve not being easy to open. (DRAIN PLUG BOLT P/N 90040-P8A-A01 and DRAIN WASHER (18MM) P/N 90401-P8A-A00 - approx $15)
A few other items to consider since you are under the hood are:
Good luck as the savings is about $1k+ in labor alone (maybe more for the comprehensive refresh I did). Definitely have the PDF service manual close by as you will want to reference it along the way (my best friend for everything completed above when I wanted to confirm the approach reference on the Acurazine forum to Acura's Service specs). - found within the forum
Description Honda Part #
- Automatic Adjuster 14520-P8A-A01 (for 2004 on)
- Automatic Adjuster 14520-P8E-A01 (for 99-03)
- Timing Belt Adjuster 14510-PGE-A01
- AC Compressor Belt 38920-P8C-A02
- Power Steering Pump Belt 56992-P8A-A01
- Timing Belt 14400-P8A-A02
- Timing Belt Idler 14550-P8A-A01
- O-RING (8.8X1.9) 91302-GE0-000 (for oil dip stick)
- WATER PUMP (YAMADA) 19200-P8A-A02
- O-RING (13.0X1.9) 91345-RDA-A01 (PS Steering gasket to avoid inlet joint issues - it is a common problem)
- Filter (ATF) 25450-P7W-003
- O-RING (12X2.4) 91301-P7W-003 (to replace washer on bottom bolt)
- Spark Plugs - Depending upon you mileage your spark plugs may also need changed which is approximately $60 from your local parts store. I used the standard NGK issue although some on the forum are using the new version of plugs)
- Seafoam treatment - well worth the investment (2 cans - $12 to $20)
- Throttle Bottle Cleaning - a great follow-up to the Seafoam treatment to ensure that everything is in order (3 bottle of Throttle Body Cleaner - DIY article available.
RONE (11-11-2015)
wholesalepartsguy has the 105 kit from santa rosa acura if you want OE stuff
14400p8aa02, 14510pgea01, 19200p8aa02, 1999, 2003, 90040p8aa01, 90401p8aa00, acura, acurazine, belt, honda, idler, mdx, part, pump, timing, water
