thought I was home free...
Old Mar 6, 2011 | 03:39 PM
kaptainjack's Avatar
YoungatHeart
then the tranny eatin' monster hit us...'03 TL-S <71K...try to keep it short and sweet but would like comments, opinions...thanx
no problem before thursday...VIN# was outside range, oil jet installed on recall...anyway, trying to accelerate on highway...car stutters, bucks and hesitates...ease off gas, seems OK but dash looks like pinball machine...CEL, VSA, Warning triangle..all lite up
got home, shut her down...drove again later...seemed OK, only CEL on now...but knew something not right...shifted out of D5 (never blinking) and engine seemed in neutral no matter what D#...shut it down...started it up, got home...
bottom line...took it to Acura...everyone knows the diagnosis...new tranny needed...$4250 if no assistance from Acura...told them no way...I said I'd pay for labor, nothing else...I said $1800, he said lets try $1200, even waived diagnosis fee of $125 for Me...he's going to call Acura monday with details...he'll let me know monday afternoon...can get it done outside Acura for about $2000 but feel safer with Acura...
So, sound legit?..I think so...I feel the dealer already knows what's in store or what he can offer Me but has to go through the motions...go with Acura if they do a good will thing? (where it costs less than the shop price)...otherwise the outside shop and dump it ASAP?
thanx guys...
Old Mar 6, 2011 | 07:06 PM
01tl4tl's Avatar
thats about it
as for paying labor only--that would be 4 hours to remove and install unit
the acura rebuilding place does all the rest of the real labor
but you have given them a number to work towards- thats what matters- what will it take to make this customer happy
if they will meet it after 2 attempts, go for it!
comes with 3/36 that appearently only applies to you- verify that with dealer..just rumor at this point on non transferable
outside shops are always a risk- at least the place acura uses does them every day
Old Mar 6, 2011 | 07:10 PM
01tl4tl's Avatar
SM only knows what has been done in the past-
and each case is different--based on your brand loyalty- use of acura service dept- being a decent person who ask nicely,, and is a member of the internets largest gathering of acura whackos,,I mean enthusiast
the regional rep works for corp- thats who makes the decision
dealer is a private biz and can cut their end,, but not the 2 grand acura wants for the trans wholesale
Old Mar 7, 2011 | 06:42 PM
dan lazer's Avatar
~~~ SKY'S THE LIMIT ~~~
soooo wait-----if our cars needs a tranny----i can go to the dealership and they will do it under the factory recall or what---i got my 99 TL from this dude in alabama and i have no idea if the tranny was replaced ???
Old Mar 7, 2011 | 07:21 PM
Carbuff's Avatar
Original Owner / Oct 1998
The '99s 4-spd 'Box is a lot more reliable than the later 5-speeds used since '00.
Just keep the tranny fluid fresh (with Honda/Acura fluid) and you'll be OK.
Old Mar 7, 2011 | 09:42 PM
01tl4tl's Avatar
the recall was only to install an external oil ket kit- it goes in the normal atf filler hole on top of trans
that fixed a certain problem thats not relatred to the clutch pack wearout
No they wont give your 99 a free trans!!!
unless it has a 5 speed and it never got the kit-- and has certain heat damage from lack of that kit
then warranty replaces it--but dont count on that
look at your trans from above- blue paint on the bolt heads for big bolts that go thru trans--means warranty unit
see main tranny failure thread for more info
see about changing external filter and cleaning selenoids
Old Mar 7, 2011 | 10:31 PM
dan lazer's Avatar
ok guys---thanks alot----i never knew about the blue paint---i'll ckeck it out when i bring my car outta storge from the winter !!
Old Mar 8, 2011 | 07:01 AM
YoungatHeart
thanx for the info 01tl4tl (sorry, that's all I know you by)..dealer submitted papers to corporate yesterday..guess it will take a day or 2 for answer...
Old Mar 8, 2011 | 09:35 AM
05TSXPAT's Avatar
It took a week and a half for me.. luckily they gave me 50/50. Hope you get the same.
Pat
Old Mar 8, 2011 | 06:36 PM
dan lazer's Avatar
hey guys---i ckecked and my tranny has the BLUE PAINT on it----but honestley---somtimes when im in reverse and i shift into drive----its like a fuckin slam------like it slams into drive----it definetley feels weird-----WHAT CAN THIS BE ??????
THANKS GUYS-----THIS FORUM HELPS ME OUT SO MUCH !!!
Old Mar 8, 2011 | 07:28 PM
03tl-s04mdx's Avatar
Motor mounts?
Old Mar 8, 2011 | 08:57 PM
01tl4tl's Avatar
replaced trans doesnt mean fixed--just rebuilt~
ck your motor mounts= especially front, pass side, and rear
ck fluid level and condition
slamming into gear can be a clutch prob or fluid clogged with crud causes excess line pressure
Old Mar 8, 2011 | 09:01 PM
01tl4tl's Avatar
the front and rear mounts are fluid filled, and most years are vac boosted
look from under the car up at the mount for fluid traces,, same as blown shock does.
front often goes after 60-70kmiles, if not fixed- the side mount follows and finally the rear
Can do brake hold while quick rev in gear for front and rear,,lots of vids of testing procedure
Perform standard prybar test for side mount-its normal
Old Mar 8, 2011 | 10:12 PM
And I'm guessing this could be related to the p1738, 2nd clutch pressure switch issue you posted in another thread.
Old Mar 8, 2011 | 10:53 PM
dan lazer's Avatar
yea it could have sumthin to do with the other thrend i posted-----i do remember lookin under the car yesterday in my garage---cuz i have it stored for the winter-----AND I ACTUALLY SEEN THERES A LINE GOIN TO THE TRANNY----im guessing thats the shift cable---BUT THERES LIKE A FOAM SLEEVE ON THERE---AND THERE IS FLUID ON THAT LINE-----what can this be ya think ??????
thanks guys
Old Mar 8, 2011 | 11:28 PM
01tl4tl's Avatar
is it totally under the car as in shift cable as you thought?
did you get a sample of the fluid on your finger? atf or engine oil
You might have a rear main seal leak from engine (just throwing out possible things)
remove the inspection plate under trans to engine connection, 10mm bolts hold it on
If engine rear main goes it will leak down there and drip many places
If reddish fluid thats atf and has no business being there
storing the car- are you letting it sit with some preservative like stabil or seafoam in the oil- gas --thats the ok method
or is it started and run 10 minutes,,thats worse than sitting and may lead to oil leaks from seals,,
this is general info and may not be specific to your problem
Old Mar 8, 2011 | 11:29 PM
01tl4tl's Avatar
I wonder if thats the special oil fluid from a blown motor mount?
Old Mar 9, 2011 | 09:01 AM
dan lazer's Avatar
yea its totally under the car----it looks like it actually runs into the tranny----im guessing its the shifter cable--- i put it away in november and filled the tank with stabil in it----but honestley i start it 1 time a week and let it run for like 10 or 15 mins------but i did look at the fluid and it DEFINETLEY wasnt red fluid---sooooo im stumped here guys !!!!
thanks for the help though guys-----i really appreciate it alot !!!
Old Mar 9, 2011 | 11:07 AM
01tl4tl's Avatar
quit running it
there is moisture in the oil due to hygroscopic action--nothing short of a freeway cruise will dry it out
you are safer letting the engine just sit with the stabil in tank--and its run thru system now too.
too many possibles from rear main to oil filter seal to diagnose yet
Old Mar 9, 2011 | 04:23 PM
dan lazer's Avatar
ok ----THANKS ALOT MAN-----i appreciate it alot !!!!!!
Old Mar 10, 2011 | 10:49 AM
YoungatHeart
just an update...and an attempt to steal back MY thread..LOL
heard back from dealer and Acura pretty much will pick up about $3000 which leaves Me with about $2250...3/36K warranty...brand new rebuilt?...I politely told him I couldn't afford that and if Acura wouldn't budge maybe the dealership could. I'm sure there's plenty of gravy in these prices to allow the deal to much a little towards My figure. I told him it doesn't have to be a whole lot, just a few hundred to show good faith. We'll see what happens.
So now some more questions...if I'm on the hook for the whole $2250 what's the opinion out there?...if the SA gets it below 2K, I'm sure I'll go for it...should he get a little bonus from Me?
Stay tuned for another update if interested....
Old Mar 10, 2011 | 10:50 AM
YoungatHeart
correction to the above....math says Acura will pick up only $2000...my bad!!
Old Mar 10, 2011 | 01:47 PM
05TSXPAT's Avatar
Just got my car back today.. I paid 2200 for the Tranny and ECU on a 50/50 goodwill deal from Acura.
Are they asking 2250 from you? Is the ECU included? If it is, then its about the same deal I got. I went to someone suggested by a good friend and he told me 2800 to rebuild the old one.. yikes.
Good luck.
Old Mar 10, 2011 | 02:05 PM
05TSXPAT's Avatar
I also had them do the 105, minus plugs (I changed them 5k ago) and valve adjust (not enough money).
kaptainjack, I think you should try to have them, do more since you are at <71K, but be careful not to over reach. 2250 might be your best price, maybe?
P.
Old Mar 10, 2011 | 02:19 PM
YoungatHeart
^^ thanx for the info and suggestion..I agree about over reaching...I don't want to cut the nose to spite the face...if I know Me, if they stick to their guns I'll probably go with Acura just for piece of mind (but don't tell them I said that)...outside shop said 2000/2200 so not much difference at all...thanx, again
Old Mar 10, 2011 | 02:50 PM
05TSXPAT's Avatar
I agree. Remember that the Acura Tranny is an updated one and should last you longer also a new ECU. Outside Shop is probably rebuilding it for about the same price of an updated one from Acura with a 3/36 piece of mind.
Check out the tranny failure thread. I just posted pics of the updated transmission.
https://acurazine.com/forums/showthr...566833&page=79
Good luck in whatever you chose.
Pat
Old Mar 10, 2011 | 04:01 PM
01tl4tl's Avatar
ecu is only changed on certain VINs
the `post 2005` made units are in the `improved design case`
Suggest rebuilt trans owners now get on a yearly 3 qt fluid change schedule
Old Mar 10, 2011 | 04:02 PM
01tl4tl's Avatar
shops will use the best parts avail,,ie different clutches
acura rebuilder uses acura parts~
so the case design type is the big issue
Old Mar 14, 2011 | 07:59 PM
YoungatHeart
final update for those interested...
went to AAMCO just for second opinion and reinforce My thoughts of going Acura, regardless...AAMCO quoted Me $2500-3500 (sure it leans to higher end) with only 1yr/12K..additional $700-800 for 3yr/36K...when I pulled out of AAMCO car was much worse...D5 flashing (wasn't before), VSA lite (wasn't before), warning triangle lite (wasn't before)...engine revving/late gear shift...downshift with a thud at stop...JEZZZ!!
brought it right to Acura...$2250 for trans, $300 for ECU, 3yr/36K warranty...somewhat peace of mind...PRICELESS!!!
thanx all for listening....LET'S GO RANGERS!!!!
Old Mar 15, 2011 | 09:00 PM
YoungatHeart
had to go down to Acura to bitch and squack about a loaner her hadn't come thru with...finally got a call tonight to come pick one up...2010 ZDX SH/AWD w/5700m...nice change but I'd never buy it...
NitroViper
Mar 20, 2017 09:50 PM
01CLOwner
Oct 9, 2015 01:07 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Sep 17, 2015 09:01 PM
