TCS light?
Old Nov 12, 2009 | 06:51 PM
JimBre908's Avatar
TCS light?
Hello everyone, my TCS lights goes on and the check engine as well. I took it to a shop and they told me that im EGR valve was the problem, and that there was carbon build up in it. They wanna charge me 250 to get it cleaned. I was wondering os it cheaper to purchase a new one or get it cleaned? and if the valve need to be cleaned, what does the TCS have to do with the valve?
Thanks...
Old Nov 13, 2009 | 08:32 AM
fsttyms1's Avatar
Its not the EGR itself that needs to be cleaned but the ports. Look in the DIY thread. There is a DIY on how to clean it yourself. It is pretty easy. Should take a hr or 2 taking your time for the first time.
Old Nov 18, 2009 | 09:38 PM
psalant's Avatar
3rd Gear
Hey, I just took my 2002 Acura TL out of storage...
Hey, I just took my 2002 Acura TL out of storage... 120,000 miles, well maintained. Check engine light came on and then TCS light comes on and stays on while driving. I got out code reader and it is a knock sensor malfuntion OS325 or something like that. TCS light goes out when car shut off, but comes back on when 1 mile or so of driving.
When I went to get car, 1 front tire was totally flat. That may be affecting TCS. I pumped it up, but it may be damaged from being flat all summer. Any thoughts greatly appreciated, Oh yeah, I am unsure where DIY EGR cleaning thread. Thanks
Old Nov 25, 2009 | 02:40 PM
earthbound741's Avatar
Acura Newbe
that sounds kinda familiar.. it happened to me right before my tranny died..
Old Nov 28, 2009 | 11:17 PM
glorijo's Avatar
Question TCS light and trans leak
I have a similar situation.
First...the CEL light came on a couple months ago. When checked it read as a code for Fuel/Emissions (I believe P0401). My mechanic said something in the back needed replaced before I get my next emissions test. I forget what it was, but I am assuming it is the EGR valve?
Next thing....I have always noticed a little jerkiness with the shifting of gears, but recently it seems to have been happening more often. If I am in first gear, let off the gas, then punch it a little bit, it takes a second to shift and jerks into gear.
Last thing....the other day I noticed a leak in my driveway. It turns out it is leaking transmission fluid while driving. I added some today and I'm going to have my mechanic look at it Monday. Is this a common problem with the 99 TL trans? I am assuming the tranny is going up on me. I have to act VERY fast. I am currently at 104,500 and I believe the factory warranty was extended to 105k, am I right? And does the warranty cover this?
Old Nov 28, 2009 | 11:29 PM
friesm2000's Avatar
B A N N E D
i don't think any warrenty extension for you 4-speeders, <(in red)
Yikes
May 3, 2021 04:29 PM
Retep Nitciaj
1G RL (1996-2004)
Sep 18, 2015 10:26 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Allen_442
Sep 8, 2015 06:01 PM
