tcs i need help
Old Apr 6, 2008 | 12:14 PM
philly fresh's Avatar
Its good to be FRESH!!
tcs i need help
so i go and wash my motor today cuz it was all grimey. did the exact same procedure i always go through except today i think i messed something up. warmed the motor up, sprayed on the simple green and let sit for a few minutes. then i took water to it and drove it down the street. heres where it went all nutty. so i drive about a mile and both the check engine and tcs light came on and the engine shut of. wouldnt start. so then i put it in park and restarted and it cranked back up. so i got back on the road. well it kept doing the same thing over and over. took it autozone and had them read the codes. well thier code reader wouldnt even work with my car. kept saying error. so i drove it some more and it would go farther every time. so i took it on the free way and the samething. if i hit the gas hard it goes to 3k acts like its hitting the rev limiter and then dies. if i ease into the gas and i mean really slow i can get it up to whatever speed i want. so i drove it around on the freeway for 15 or so min got off and then tried going slow and it repeated it all over again. anyone have any ideas what it might be. im think a coil since we dont have a distributor.
Old Apr 6, 2008 | 12:57 PM
01tl4tl's Avatar
spray wd40 on every electrical thing you can get to, and stop washing the engine like that!
Old Apr 6, 2008 | 01:20 PM
ive done it this was for years. its done correctly. im assuming you thought i took a power washer to it. water hose low pressure
Old Apr 6, 2008 | 04:34 PM
01tl4tl's Avatar
water and cleaner had to have gotten into something- so regardless of how gentle a rinse it got- WD40 everything- coils- alternator- any connectors you can reach- check the fuseboxes for a blown circuit etc.
I am just trying to help
Old Apr 6, 2008 | 07:36 PM
thanks 01tl
Old Apr 6, 2008 | 07:39 PM
fsttyms1's Avatar
i would pull apart most of the electrical connections you see and make sure they are dry. Spray wd40 on them like stated above or get some dielectric grease for the connections.
Old Apr 6, 2008 | 09:16 PM
fixed. damn screwy ass cars
Old Apr 6, 2008 | 09:48 PM
01tl4tl's Avatar
what was it??
Yikes
May 3, 2021 04:29 PM
Retep Nitciaj
1G RL (1996-2004)
Sep 18, 2015 10:26 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Allen_442
Sep 8, 2015 06:01 PM
