subwoofer not working right. need azine help.
My subwoofer only works when my heat has been on full blast for like 5-10 minutes, sometimes it takes even longer than that. I have no idea how to explain why its happening. Any suggestions are welcomed. Everything radio/speaker/EQ wise is stock. Sorry mods if this needs to be in the audio section but it is more of a problem that could be fixed.
Highly recommend speaking with Factory Car Stereo Repair, Inc. in the Orlando, Florida area. Their website is http://www.carstereohelp.com/.
When I got my 99 TL last November, no sound at all, even though it was obvious that the stereo was turning on. I am in the area, so I took it by their shop. Less than 90 minutes later everything was working and checked out (someone had reinstalled a factory unit without connecting everything). Charged me a whopping $100 for the work of two guys for all that time and effort. Check out their website and give them a call.
Weird. Sounds like bad wiring or a fuse is going. Check the entire wiring line from the sub to the amp and the speakers to the radio. You won't be able to check behind the radio unless you take most of the dash apart, as that is where I'm suspecting there's an issue. This is just a wild guess but the heat may be remelting a bid of loose solder on a nicked wire allowing it to get a connection.
QueenCityTLS (05-02-2013)
If you got the stock bose system the radio the speakers & the sub, you need to get an axxes input output, check your ground & remote wires you might need to put them somewhere else, idk how you got your system hooked up though it sounds like something isnt were it belongs...
sorry but i don think anyone is understanding u all the way, define subwoofer. are you talking about the ten that comes standard or subwoofers u installed in the trunk... also what is ur climate?(whats the normal temp there)
hey guys, thanks for the responses. I am talking about the stock ten that comes with the car. stock radio. stock speakers. stock wiring. I live in NC. So the climate is mid east coast region climate.
AndrewS
19
03-14-2024 06:59 PM
sockr1
10-01-2015 01:31 AM
3GTLOwns
09-09-2015 09:51 PM
