Strange vibrating noise, driver's side/front
Old Apr 3, 2006 | 12:02 PM
skroe99's Avatar
I recently had transmission fluid changed as mechanic said it was time - 52K miles about. He did not have Acura transmission fluid so was told by someone he could use some other transmission fluid plus an additive. But since then, when I drive about 55-70 miles per hour or so, it makes a vibrating noise, sometimes constant and sometimes on and off. Sort of sounds like something rubbing or sounds like blowing through waxed paper over a comb (if anyone relates to that sound). A friend and I thought maybe it was when the transmission gets heated up that it starts up, but it can occur after driving 2 miles or it can occur after driving 40 miles. No change in the noise with speed unless you slow dramatically down to like under 35 mph. Any ideas? My mechanic is puzzled - this is the first Acura he has worked on. The closest Acura dealership is about 3-1/2 hours away.
Old Apr 3, 2006 | 12:04 PM
ITL's Avatar
ITL
I do my own work.
You MUST have fluid specific to Honda/Acura. The only alternative I've heard of is GM SyncroMesh Friction Modified, which I currently use in my 2004 6MT.
Same goes with power steering...the fluids are Honda specific!
Old Apr 3, 2006 | 12:31 PM
fsttyms1's Avatar
May be a bearing. I would get that fluid out and do a few drain fills with honda fluid.
Old Apr 3, 2006 | 02:07 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
It says in the manual you can use a DEXRON III ATF as a temp replacement. How long has it been in there?
Old Apr 3, 2006 | 02:24 PM
skroe99's Avatar
Acura transmission noise
The fluid change was done approximately a month ago.
Old Apr 3, 2006 | 02:57 PM
acurabum's Avatar
Me I would only put Honda/Acura AT fluid only and never add any additive .
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
real_mckoy
4G TL Problems & Fixes
Sep 25, 2015 10:49 PM
Robospinner
22
Sep 24, 2015 08:47 AM
AZuser
Sep 17, 2015 10:15 AM
