Steering wheel vibrates horribly!! Brake problem, help please.
Old Dec 4, 2006 | 03:54 PM
deejayceas's Avatar
Hello my fellow TL peeps, whew!!! Its been like a super long time since I've been on here.
Well anyways, I have a huge problem with my TL-S. Whenever I brake at high speeds on the freeway or even at low speeds like 30-40 mph my steering wheel vibrates horribly. I know for a fact that its a brake problem, that I know.
My main question is. Do you really have to take your car to Acura or to a shop that puts the actual machine up to your brake rotors so the rotors can get machined? I was told by the Acura serv. guys that on the TL-S you caint just take the rotors off and take them to a shop to get cut. They told me that TL-S rotors have to stay on the car and have the cutting machine for the rotors be brought up to the car to machine the rotors at the specs of the TL-S.
Now is that a bunch of BS? Or are they being for real? I took my car once already to Brake Stop and I believe those bastards took me for my money. They supposeably fixed the problem but like in 2 months the vibrating came back. They told me theres no need to do all that, that Acura says you have to do. You can take the rotors off the car and machine them.
I just want to know if anyone does what Acura says to do, or do they just take the rotors off them selfs and take them to a shop to get machined? When ever I had brake problems on my 99 2dr accord I would just fix the problem my self. I would do my own brake job at home. Your feedback would be greatly appreciated. Thanks.
Old Dec 4, 2006 | 03:58 PM
Trackruner228's Avatar
Do not hold me to this but I remember seeing a DIY on here for someone doing it themseleves.
Old Dec 4, 2006 | 04:45 PM
Blazin_TL's Avatar
Registered User
do youself a favor.. take off your oem rotors and throw them in the garbage.. get some rotora or brembo blanks and some ebc pads and you will be set.
Old Dec 4, 2006 | 05:23 PM
dreem1er's Avatar
deal with it
it sounds like your brakes are warped i had similar problems with my brakes all i had to do is resurface the rotors the car been braking perfect...........only if the rotors are to thin to resurface or too badly warped will you have to buy new ones
Old Dec 7, 2006 | 01:45 PM
LEX588's Avatar
deejay..I've noticed the same problem on my TL..the vibration seems to be getting worse..I wont be able to look into it until the weekend so let me know how it turns out in the meantime..
Old Dec 7, 2006 | 03:13 PM
fsttyms1's Avatar
Your dealer was feeding you a load of crap. You can take your rotors to any mechanic to have them turned, worked on. but like the others have said. Do yourself a favor and get rid of them and get some aftermarket rotors. They are far less likely to warp.
Old Dec 8, 2006 | 01:08 PM
deejayceas's Avatar
Yeah, I was kinda wondering about that. Most likely Im just gonna go buy a whole new brake kit. I dont think my rotors can be machined anymore either way. Yeah the vibrating has gotten worse, even people that ride with me in front feel the whole vibration, its pretty bad.
Old Dec 13, 2006 | 11:17 AM
justint's Avatar
I just put brembo blanks and ebc green pads for the front and no more vibration and better brake :-)
Old Dec 13, 2006 | 02:19 PM
drcookie's Avatar
Don't evern waste your $$$ to resurface the stock rotors. Spend your money on Rotora or some decent brand. You would feel more secure when braking.
Also, make sure you "bed" the brake pads properly. I replaced my front rotors and pads and they squeled like crazy when braking at low speed (before the car stop). After I properly "bed" the brake pads, the squealing is now gone.
Just my $0.02
Old Dec 17, 2006 | 02:35 PM
DIRTYJOHN's Avatar
Yupp I Agree With All Those Who Say Ur Oem Rotor Sucks.. They Are Crap... Throw Them Away... Get Some Aftermarket Cross Drilled Rotors.. And Get Some Good Brake Pads... Ure Setttt.... Itll Take Away That Nasty Steering Wheel Shakage.. It Happen To Me B4.. Shooked The Whole Dash Board.. I Resurface It At My Shop.. And Guess What It Work For A Good Month And Now It's Shaking Again.. I Just Ordered Some Cross Drilled Rotors And It Should Come In Soon...
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
nishant11
Sep 2, 2015 10:34 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
