SRS light after removing evaporator
Old Nov 15, 2016 | 08:30 AM
JRhodes88's Avatar
Need an OEM lip kit on my
Removed and reinstalled the evaporator yesterday and now my SRS light is on. I obviously had to unplug the yellow airbag connector on the passenger side when removing the evaporator. I tried to disconnect and reconnect the plug and also tried disconnecting the negative battery cable. No luck. The SRS light is still on.
Is there anyway to reset this or should I not worry about it?
Old Nov 15, 2016 | 08:37 AM
I believe only the dealer can reset it or more correctly, someone with an HDS
Old Nov 15, 2016 | 08:39 AM
JRhodes88's Avatar
That's disappointing. So no work around for that....bummer
Old Nov 15, 2016 | 08:40 AM
Get an HDS? it MAY be something they will do for free... MAY.....
Old Nov 15, 2016 | 08:50 AM
bring some donuts!
might help smooth the "hey, can you reset the SRS light with the HDS?"
Old Nov 15, 2016 | 08:54 AM
JRhodes88's Avatar
bring some donuts!
Just a dealership right? My normal mechanic probably doesn't have the machine? I guess I can call him since he specializes in Acuras/Hondas.
Also....the donut trick works all the time
Old Nov 15, 2016 | 08:58 AM
Call your mechanic and ask if he has an HDS TOOL!
Old Nov 15, 2016 | 09:13 AM
my mechanic has a "Snap-on" hand-held machine/tablet that controls most cars ECUs.
call your mechanic and ask if he has the handheld to reset the SRS light
Old Nov 15, 2016 | 09:17 AM
Or you can try and DIY:
ray03cls6mt
2G CL Problems & Fixes
Sep 15, 2016 04:41 PM
lanterna_viridis
Apr 18, 2016 02:31 PM
wadinson
Integra
Mar 20, 2016 12:08 AM
Michael Hinchey
Mar 18, 2016 07:18 PM
bliner01
Mar 11, 2016 02:13 PM
