SRS light is on
Old Sep 29, 2008 | 04:37 AM
boneyardjohn's Avatar
SRS light is on
What does this mean? 00 TL What is the fix?
Old Sep 29, 2008 | 04:58 AM
01tl4tl's Avatar
is it on all the time- the RED srs light?
you likely have a sensor failure
CALL the dealer for appt asap- there is a special 10 year 150k miles warranty on the system
When the light is ON the system is OFF!!
Old Sep 29, 2008 | 01:38 PM
Duriisimo's Avatar
Aguilucho del Cibao!
Mine came on, took it to the dealer, fixed under warranty and was told another sensor may go bad, which is covered also. A month later light came back on, dealer fixed it under warranty.
Old Oct 8, 2008 | 05:03 PM
mango724's Avatar
8th Gear
I have the same problem, except I had the windows slightly open one day and it POURED but by the time I came outside to close the windows was a bit wet inside already.
Later when I turned went to drive it, the SRS light came on and has been on since...sensor short, or busted??
Old Nov 9, 2008 | 04:39 PM
The_R1Ky_Kid's Avatar
~It Aint Eazy~
Thanks guys, Exactly what I needed.......
Old Nov 9, 2008 | 07:53 PM
01tl4tl's Avatar
did you just do a reset, or go to the dealer and get warranty fix?
Old Nov 19, 2008 | 03:25 PM
SickWhip's Avatar
I took my 03 TL-S in for trans problem and also had the SRS problem. I was so worried about the trans that I forgot to ask about the light. The service manager brought it up when I called back later. Said he'd fix it under warranty for me.
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
mugen_kid
Nov 13, 2015 10:38 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
