someone please enlighten me!!
Old Apr 8, 2013 | 11:47 PM
lexius1's Avatar
I have a code p1259 coming up on my 01 3.2 tl. How does the electical work on the vtec system? My cel is coming on immediatly upon turning the key, which tells me its electrical. But I dont know where to check for what?
Old Apr 9, 2013 | 06:52 AM
fsttyms1's Avatar
First thing to check is your oil. Is it to the correct level? If so the next thing i would do is make sure the connectors/wires are connected to the vtec oil pressure switches (on the oil pump near the oil filter.
Old Apr 9, 2013 | 11:58 PM
lexius1's Avatar
Thanks, I have checked both the connector and the oil level. What should I check next? Can the vtec oil pressure switch be jumped?
Old Apr 10, 2013 | 09:02 AM
fsttyms1's Avatar
Old Apr 10, 2013 | 04:56 PM
lexius1's Avatar
Thank you so much fsttyms1, this is exactly what I need! I'll be working on this tomorrow for sure.
Old Apr 11, 2013 | 07:49 AM
fsttyms1's Avatar
Old Apr 17, 2013 | 11:36 PM
lexius1's Avatar
Much thanks fsttyms, vtec oil pressure switch was bad. $50 part solved my problem!!
Old Apr 18, 2013 | 12:04 AM
lexius1's Avatar
Hey fsttyms, another quick question. While I was doing this repair I went ahead and did an oil change. Now I'm getting the maint. rqd light flashing at me a few times when I first turn the key on. Is this light just a reminder for oil change interval? If so how do i reset it? When I bought this car it didnt have an owners manual.
Old Apr 18, 2013 | 07:06 AM
3.2TLc's Avatar
Hey Lexius1, the maintenance reminder light will flash at 7500 mile intervals. If you have an owners manual, the reset procedure is in it. If the manual is misplaced, here you go :
To reset the light with the key off, press and hold the trip mileage reset and select buttons, while turning the key to the ignition on position (not running), keep both buttons pressed for about 10 seconds until you hear a beep and the light goes out, then turn key off and release the buttons. You'll be good for another 7500 miles before it re-activates !
Old Apr 19, 2013 | 11:59 PM
lexius1's Avatar
Hey thanks for that 3.2tl. Is 7500 miles the suggested oil change interval for these cars? I'm running synthetic 5w20.
Feb 17, 2006 10:49 PM
