Should I changed my transmission fluid?
Old Aug 4, 2009 | 11:35 PM
asianstyle's Avatar
My wife's 2000 tl has 170,000. We bought the car with around 70,000 miles. not sure if it had ever had a fluid change before then. My question is, since there are so many miles now should I even bother changing the fluid. I hear from people that it will make the transmission worse. Every now and then it will take longer than normal to shift gears so I'm assuming it's just a matter of time before it craps out. I just wanted to try and prevent it from happening. should i change or not change, that is the question?
Old Aug 4, 2009 | 11:56 PM
xtremex626's Avatar
Regional Coordinator (SoCal)
You basically put 100k more miles onto the car since you had it. Changing the transmission fluid is part of normal maintenance so I believe you should change it, especially knowing the 2G TL is notorious for it's tranmission failures...
Old Aug 5, 2009 | 01:16 AM
miamirice's Avatar
Yup
holy cow 170k...i'd do a drain and fill only...drain once and fill once. then do it again after a few weeks. can't be too careful with these things. do it yourself...don't let a shop do it. you can make sure you do it right - plus it's really easy and cheap.
Old Aug 5, 2009 | 01:22 AM
asianstyle's Avatar
yeah I can't believe we've made it this far. I must be one of the lucky ones. anyone have a write up on how to do this? Just wondering b/c I've never done this before.
Old Aug 5, 2009 | 06:53 AM
fsttyms1's Avatar
Look in the DIY thread.
Old Aug 5, 2009 | 10:26 AM
asianstyle's Avatar
thanks i found some.
Old Aug 5, 2009 | 10:30 AM
spiro's Avatar
I would rec doing it every oil change going forward for the next 5 oil changes.
Old Aug 11, 2009 | 09:36 AM
webmastir's Avatar
2003 TL
i'm in a similar boat as the o.p. of the thread. my question is what's the point/advantage of drain & refilling the same fluid?
Old Aug 11, 2009 | 10:21 AM
FirePR2002's Avatar
bringin lead
^^who says to refill with the same fluid? should be new fluid for the refill.
Old Aug 11, 2009 | 10:57 AM
totaledTL's Avatar
That would be the same as putting your old oil back in-
Clean the drain plug magnet too.
Old Aug 11, 2009 | 11:41 AM
webmastir's Avatar
2003 TL
oh lol. i misunderstood...doh.
Old Aug 11, 2009 | 11:49 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Drain/fill. Drive through all of the gears. Come back, drain/fill. Drive through all of the gears, and then drain/fill one last time.
Drain/fill 3x total, and you'll have new tranny fluid thoughout the car, totally eliminating the old fluid.
Oh, BTW, DEFINITELY change out your fluid. ASAP.
Old Aug 11, 2009 | 12:00 PM
FirePR2002's Avatar
bringin lead
i wouldn't do the X3 on this particular case, just the drain and fill once.
Old Aug 12, 2009 | 11:51 PM
asianstyle's Avatar
thanks, I'm gonna go with the drain and fill once for now. then do it again on my next oil change. doing it tomorrow.
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
nanos
Nov 12, 2015 08:41 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
quake97
Aug 30, 2015 07:57 PM
