ShiFTER STUCK IN PARK!
some1 plz help. my car just started acting up 2day, the shifter wont move from park unless i click the release button with the key, then start the car. I read sumwhere else its the brake sensor and I believe it is b/c i checked and when i press the brakes, my lights in the back dont come on, how can i fix this??
Keep It Simple in
brake switch by the brake pedal or the brake fuse. Make sure your brake lights are turning on. If theyre not turning on, its the brake switch.
https://acurazine.com/forums/showthr...ght=stuck+park
MERRY CHRISTMAS!
MERRY CHRISTMAS!
webmastir (07-02-2011)
Check to see if your brake lights work. Odds are its the brake switch. Sometimes its the fuse but 99.9 % of the time its the switch
Professional Wrestler
This happened to me about 2 months ago. Of course, I was out of town and it was my wife that had to discover it on my car, she was friggin pissed. You have to have your foot on the brake to move out of park and there is a solenoid the engages to block the shifter from moving over far enough to get out of park. If the sensor can't tell that your foot in on the brake, no solenoid. The sensor is a push-button that is engaged by the back of the pedal arm and is a pretty common problem.
In the interim, you can use a screwdriver to override it by flipping out the little plastic thing to the right of the shift gate on the trim. This will push the solenoid out of place and allow you to drive. It has to be long and slender, try not to scratch the trim. Be careful though, because you will have no brake lights, keep your eye on the rearview mirror and no sudden stops with someone behind you.
I bought a replacement from Autozone and changed it in about 20 minutes, no problem and back up and running.
just had this happen today. glad it seems like simple fix, thx!
If I take the little shift plate out and press the button down the car comes out of park, but once I start the car can I put it back in so that my brakes work? My repair guy isnt open on the weekend and of course it happened on the weekend, on a rainy day when I really need my brake lights.
first have a helper see if you have any brake lights working- or not
then remove the little cover and insert THE CAR KEY- push it straight down
it is made to do this-
foot on brake, Now shift to Nuetral- remove key- start car, put in any gear except P and you are ready to go
Every time you go to P, you have to override the safety warning lockout
of course DO NOT drive without working brake lights
you will be at fault in the accident!
if brake lights all work its the other sensor
if no brake lights- brake sensor
For the car that blew fuse= that didnt happen for no reason- something is causing a short in the system
ReCKeD (04-10-2015)
the override doesnt affect your actual brakes- it overrides a sensor system made to let you know there is a problem somewhere
a bad bulb problem should trigger a dash warning Brake bulb (depends if your year has that)
Gotcha, sorry I meant to say brake lights, not brakes. It worked... when I put the little plate back in after I took it out of park, the brake lights work(well one of them does but ones been out for a couple of days)... so at least I can "rig" it that way this weekend until I can bring it in to be fixed. I am not particularly knowledegable about cars, but is it simple enough a fix for me to do myself if it really is just this sensor? I really would rather try and fix it myself if I can. Could this have occured from one of the brake lights going out a couple of days ago?
if you get brake lights its not the brake bright trigger/sensor
UNLESS
its become loose at the mount- ck it out!!
start with new bulbs, special ones of course!! at least the dead one and its match across on the other side or do all of them and its done
One bulb goes and the others follow!
simple diy to replace rear bulbs
UNLESS
ReCKeD (04-10-2015)
you can leave the small cover off and stored until this problem is fixed
this thread is still helping ppl out....
shit happened to me just now....shifter got stuck at gas station out of no where.
one of my tail lights had gone out earlier...i pulled the burnt bulb out to check the size. bulb socket shorted out on screw of taillight cause i didnt put back in properly.
fuse ended up being the issue...wouldnt have known where to start
01tl4tl (04-13-2015)
thanks for sharing your experience, it does help- first time I heard of popping the fuse while changing the bulb
Its unusual to screw up the install, what step did you skip? what exposed screw ??
guyvelella
09-30-2015 11:02 PM
