Shaking under load (bet. 45-60mph)
Old Jul 31, 2011 | 11:23 AM
mestizoracer310's Avatar
Can't find the previous threads, but I seem to remember it was the inner cv joint of the axle. Replaced it quite some time ago and then "more recently" it started shaking again. I say "more recently" because I don't drive much (ride my fixie to work)....I also replaced the front mount that was bad. So what gives?
Old Jul 31, 2011 | 01:55 PM
ANC297's Avatar
Bonki' Ehrite!
Get your wheels balanced and see if that helps....
Old Jul 31, 2011 | 04:13 PM
01tl4tl's Avatar
shake on accelleration is most often a bad cv joint, the inner ones iirc
You may have replaced one side of the car, but there are 2 axles~
did you replace 1 bearing or the entire axle assembly, new is better than rebuilt ~100$
LA roads not cv's best friend
even brand new parts can fail or year old
Get it on a lift for inspection, alignment shops should help you out
Old Jul 31, 2011 | 04:14 PM
01tl4tl's Avatar
ck the other mounts--once front goes,, the pass side follows
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
prbori
Sep 27, 2015 01:37 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
redsox68
Sep 16, 2015 06:18 PM
