Shaking under load (bet. 45-60mph)
Can't find the previous threads, but I seem to remember it was the inner cv joint of the axle. Replaced it quite some time ago and then "more recently" it started shaking again. I say "more recently" because I don't drive much (ride my fixie to work)....I also replaced the front mount that was bad. So what gives?
shake on accelleration is most often a bad cv joint, the inner ones iirc
You may have replaced one side of the car, but there are 2 axles~
did you replace 1 bearing or the entire axle assembly, new is better than rebuilt ~100$
LA roads not cv's best friend
even brand new parts can fail or year old
Get it on a lift for inspection, alignment shops should help you out
ck the other mounts--once front goes,, the pass side follows
joflewbyu2
10-08-2015 11:16 AM
