shake in steering wheel
Old Apr 24, 2009 | 07:16 AM
  #41
hANDYcaptd's Avatar
It's the Halladay season!
Originally Posted by twistedwedge
Seriously-how could it warp anything? The rotor is a flat piece of metal sandwiched between two other pieces of flat metal (hub, wheel). Long as you start and snug the lugs in the proper sequence and then torque- even if they are a little tighter than spec how could it warp anything? Im not trying to call you out Kris, just curious.
Going a little over spec is fine, as Kris said.
But going wayy over spec causes high stress in the hub area that migrates to the contact area. The additional heat stress can then warp it. Also, over torquing the hub area will cause the contact part of the rotor to bend outward slightly. (verrrrrryy slightly, but then again it doesn't take much to feel vibration.)
Old Apr 24, 2009 | 07:19 AM
  #42
twistedwedge's Avatar
6MT Someday..
I could see that happening if someone had the rotor off the car, put it back on and there was foreign material between it and the hub (rust, metal or other debris). What do you consider "wayy over spec"?
Old Apr 24, 2009 | 07:23 AM
  #43
fsttyms1's Avatar
It can happen clean. The hub area has more than enough area to distort from excessive pressure.
http://www.tirerack.com/wheels/tech/...jsp?techid=107
IMPORTANT!
Proper installation requires that the wheel lug torque be set to the recommended specification for your vehicle. Sometimes these torque specifications can be found in your vehicle's owner's manual, however more often than not you will need to refer to your vehicle's shop manual or obtain them from your vehicle dealer/service provider.
Unless specifically stated otherwise, wheel lug torque specifications are for clean and dry threads (no lubricant) that are free of dirt, grit, etc. Applying oil, grease or anti-seize lubricants to the threads will result in inaccurate torque values that over tighten the wheels.
A thread chaser or tap should be used to remove any burrs or obstructions of the threads allowing the lug hardware to be turned by hand until it meets the wheel's lug seat. Once lugs are snugged down, finish tightening them with an accurate torque wrench. Use the appropriate crisscross sequence (shown below) for the number of wheel lugs on your vehicle until all have reached their proper torque value. Be careful because if you over torque a wheel, you can strip a lug nut or hub, stretch or break a stud or bolt, and cause the wheel, brake rotor and/or brake drum to distort
Old Apr 24, 2009 | 07:36 AM
  #44
6MT Someday..
so, over tighten by say.. 20 ft/lbs, you think its going to warp things? I know that whaling on lug nuts with an impact gun or really cranking down on them can break studs, Ive just never understood the whole warping rotors side of it by over tightening the lug nuts a little too much.
Old Apr 24, 2009 | 08:22 AM
  #45
Acuracy02's Avatar
運転することを愛
I've had problems with Hondas and their steering wheel shake for many years. For me it was always more noticeable on a tire with a thinner profile. I tried many, many wheel balancings on various Hunter balancers (different locations) and to no TRUE avail. Things would improve, but with a low profile tire there is so much room for feel of the road. At times (NOT ALWAYS) my steering wheel would shake on the freeway with my 19's on, however when I have my winter wheels on with high profile sidewalled tires, the steering wheel is solid as a rock.
Part of this is that the extra rubber pads the vibration you might receive. A tire is actually all over the place if you were to see it in slow motion, the rubber is twisting and turning in every direction like a blob, so the less of this you have between your wheel and the road must have a significant effect.
I'm not disregarding the rotor/caliper situations described above, I am just saying that wasn't the case for my two vehicles, following before and after brake change test scenarios.
Old Apr 24, 2009 | 08:31 AM
  #46
Flipster23's Avatar
It is true kuz now im not getting vibration after taking it to the tire shop
Old Apr 24, 2009 | 11:06 AM
  #47
totaledTL's Avatar
Just installed new EBC rotors & pads, all is smooth so far.
Old Apr 24, 2009 | 11:21 AM
  #48
TLer trash's Avatar
Originally Posted by totaledTL
The wheels and hub also help to dissipate the heat generated by braking. If the heat transfer isn't uniform it can possibly lead to warping of the rotors. Make sure the hub and back of the wheel are clean, rust free and flat. Uniform torque applied to each lug helps to ensure this. Also tighten them in stages rather than applying full torque to each nut individually.
I agree, especially about torquing in stages. I don't think this gets mentioned enough.
Old Apr 24, 2009 | 11:56 AM
  #49
fsttyms1's Avatar
Even that can do it. Get yourself a torque wrench and make sure things are tightened properly. Especially tightened "Equally" that is probably the biggest reason. One may be 70 one may be 100.
Old Apr 24, 2009 | 02:22 PM
  #50
Tommy99TL's Avatar
Tom
That's interesting to know... thanks Kris.
  #51
6MT Someday..
I always use a torque wrench..Im just having fun debating with you over this
Old Apr 24, 2009 | 03:48 PM
  #52
1st timer's Avatar
UB6IB9
Originally Posted by fsttyms1
Rotors.
Also make sure your wheels are torqued properly. Over torqued wheels will do it too.
What is the propper torque ? 80lbs??
Old Apr 24, 2009 | 03:57 PM
  #53
6MT Someday..
Yes the lugnuts. If tightened too much it can cause the rotor to warp. 80 LB/FT
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
EvilVirus
Dec 10, 2015 07:38 PM
04tler
Sep 10, 2015 04:03 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
