Serpentine\Drivebelt routing diagram
Hello, I have a 1999 Acura Tl and im looking for a serpintine\drivebelt routing diagram, Just finishing up my timing belt, water pump, idler pulley, tensioner pulley and hydraulic tensioner. Thank You.
Don't mind that is for a ford we use the same layout in the 2G
This is the Diagram for the Timing belt just in case you also need it.
The power steering belt is pretty straight forward.
Thank's skirmich, Look's simple and easy installing the drivebelt...I appreciate the timing belt diagram, The timing belt replacement on our Tl's are straight forward and not hard to do, The only thing's in my opinion that's a real pain is the crank pulley bolt and very little space when taking off the upper timing belt cover's and the screw that goes into the oil dipstick tube...Thank's again and happy holiday's. :-)
quanaman
01-09-2023 07:33 PM
AmplifiedDetails
09-24-2015 02:55 PM
