Sensor code help
Sensor code help
I just got back from the Honda dealer with my 02 tl-s. I have a ABS & VSA light on. They agreed to read the codes for me but could not reset. This is what they pulled. "703 codes 26-1/11-1/13-1/14-1 Stored 26-1 Lateral Acceleration sensor Failure, 11-1 right front wheel sensor, 13-1 & 14-1 left front wheel sensor." I put the car on a lift to inspect the wheel sensors, rerouted left front as it was wound around wrong side of steering knuckle, but found no damage. Inspected under hood to make sure they were plugged in. All OK.
History of this car is it was in accident. Someone did some body work. I have driven the car for about 1000 miles with codes hoping they might clear on their own. Guess that was wishful thinking. Looking for how to proceed. Honda would not work on car further, said to take to Acura dealer (100 miles away). Can anyone out there offer some direction? Thanks.
I would replace the 2 wheel sensors as if they were routed wrong they may just be damaged. Also double check the wiring to make cure its not cut further up?
As for the L-A sensor?? I wold see if one of the wheel sensors are causing that to trigger.
Jamus22
06-11-2023 10:08 AM
