security system
Old Jan 19, 2006 | 03:54 PM
VancouverTL's Avatar
6th Gear
security system
Am a proud owner of a 99tl ,no books came with car.the light on the drivers door does not light up, and could someone tell me how to test the alarm.thx
Old Jan 19, 2006 | 04:15 PM
Phesto's Avatar
I dont think the stock alarm came with shock sensors,good question on how to test it.Does it still beep when u activate it or do you only hear the doors lock??
Old Jan 19, 2006 | 04:36 PM
6th Gear
phesto there is no beep just the doors lock...any words of advise as I am handy at fixin cars but without a wiring diagram or knowing ho the system works I'm at a loss
Old Jan 19, 2006 | 06:46 PM
Bambo2888's Avatar
they go wooooot wooooot
emm, you might want to sit in the car, lock/arm it, then open the door from inside and see if the alarm goes off. that would simulate the car being broken into while armed. let me know what happens. good luck.
Old Jan 19, 2006 | 07:01 PM
Phesto's Avatar
With no Beep, it would seem to me that the system is not working.I think if you do a search you might find some info on wiring.....Otherwise go aftermarket Clifford and Python (Ihave) have some nice two way pager alarms,you always know whats up with your car.I've seen them advertised for like 300-350 installed in my area it might be cheaper in you area, since the SF has like the worst cost of living around
Old Jan 19, 2006 | 07:03 PM
Phesto's Avatar
Good Luck
Old Jan 19, 2006 | 08:42 PM
Bambo2888's Avatar
and ive got a viper 791, remote start, two way all that jazz. best investment if youre obsessed with your ride. plus you can start it
Old Jan 19, 2006 | 11:43 PM
khoifl's Avatar
how much did you pay for installation? and the unit itself?
Old Jan 20, 2006 | 09:46 AM
Phesto's Avatar
The Viper is good too.Directed Electronics makes Viper,Python.. In the end what is piece of mind worth.I Think i sleep better at night...
Also Vancouver look into a Starter/Gas Kill Switch,Even if they break into the car, it insnt going anywhere with no gas
Old Jan 21, 2006 | 12:27 PM
Bambo2888's Avatar
when i originally got it last year, i had it installed onto my maxima for 450, that was everything, labor, parts, the alarm, relays for trunk and whatnot.
when i totalled the max, i ripped all the shit out and a friend and I installed it onto the tl. it took a long time and a relatively extenive knowledge on wiring. if you dont mind researching and using www.the12volt.com, youre all good and will pay just the alarm price.
i defintely would say go for installing it yourself. itll take some time, but youll know everything about the alarm and be able to locate/position things to make sure nothing is bypassed by theives (i ran everything from the trunk with an extra battery, everyone expects it to be under the steering wheel, SUPRISE!)
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
