Rusty brake calipers
Old May 7, 2007 | 08:54 PM
orgnlprankster7's Avatar
08 Civic SI
both my front calipers have rust inside the piston, they seem to not fully retract after they heat up causeing the pads to stay pressed agaisnt the rotors, which is why my new rotors are starting to warp. anyplace i can get new calipers cheap? or can i fix these?
Old May 7, 2007 | 09:40 PM
fsttyms1's Avatar
The inside doesnt matter if they are rusty. Its the surface on the outside(where it contacts the rubber boot.
You can get them at most parts stores reman cheep. You can get the legend 2 piston calipers that are a direct bolt on for like 45 each
Old May 7, 2007 | 09:46 PM
08 Civic SI
yea i heard about useing legend calipers, where could i get those, and would i have to change rotors/pads?
Old May 8, 2007 | 09:08 AM
phipark's Avatar
Not Asian
You can get them at napa or advance auto parts. Everything else is the same, just new calipers.
Old May 8, 2007 | 11:04 AM
08 Civic SI
thanks ill go check that out
Old May 8, 2007 | 11:47 AM
01tl4tl's Avatar
OP7
Put a block of wood in the caliper so the piston can be pushed out a little- but not farther than if it was in the rotor with pads.
That will allow inspection of the hidden, "outer surface" of the caliper piston. the part with the rubber seal. If anything bad there- you found your problem
I am GUESSING that being an east coast car, and possibly never having the brake fluid flushed could be a factor in some corrosion
Legend 2 piston calipers you say- think I may need to replace mine!
Old May 8, 2007 | 11:55 AM
fsttyms1's Avatar
Originally Posted by 01tl4tl
OP7
And yep. direct bolt on, just remember to put the right side caliper on the left and left on the right or you wont be able to bleed them properly
Old May 8, 2007 | 12:02 PM
08 Civic SI
oh one more thing, what year calipers from the legend would i need?
Old May 8, 2007 | 12:23 PM
phipark's Avatar
Not Asian
95 Legend Coupe GS.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
