RPM's problem
RPM's problem
Early sunday morning about 1 minute later after starting my car the RPM's started going up and down for no reason , so I turned the car off turn it back on and no more problem. Any ideas what that was about?
Skeet Skeet Skeet
Sounds like a IAC
Skeet Skeet Skeet
Is it something I should replace ASAP, i mean will leave me stranded someday if i don't replace it soon? Sounds like a bitch to replace. Is this another common TL problem?
Also a couple of weeks ago after driving for a little while pulled over to get some lunch. Started her up again and it studdered then turned off, it did this for about 3 times, then it was fine, is that the IAC malfunctioning?
Originally Posted by honda_inspire99
its pretty easy to do i just tried cleaning mine this morning to see if it would fix my problem but it didn't.
Skeet Skeet Skeet
Yeah i saw you got an error code cleaning it, would you recommend relacing it instead?
99 SSM Tl
If your Iac is defective and you whant to change it .. just clean it before.. if its doesnt work .. maybe buy a TypeS tb will be cheeper.. and its bigger so ..
Skeet Skeet Skeet
Originally Posted by optomos
SidhuSaaB
05-30-2020 12:40 AM
